my car got much quicker today for a while...
(In Topic #80375)
![Avatar](https://i34.photobucket.com/albums/d109/cabriaulait/tijn.jpg)
![cabriaulait in the usergroup ‘Local hero’ cabriaulait in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
i found it and reconnected it and i was back 2 normal, so i took out the airfilter and give it a quick hoover and clean up, that helped,
then disconnected the air ram at the air filter box, and that helped some more,
so im thinking of rerouting the air ram, and making an extra one to fit to the bottom of the air box, not huge but to a colder air feed, near the headlights,
and a high flow filter.
am i missing something here or is that all plausible
opinions please
rebuild in progress....
![G-DUB in the usergroup ‘Old timer’ G-DUB in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
that same pipe also goes to somewhere in the lower middle of the inlet manifold (the bit the throttle body joins to)
what does that pipe do?
its in next thursday,
has been stood for yr so could do with a tune methinks
![](https://vwgolfmk1.org.uk/uploads/pbextract/667561/fater001.jpg)
this it it disconnected
![](https://vwgolfmk1.org.uk/uploads/pbextract/667561/fater002.jpg)
and this is the bit that i dont know what it does(with stick)
![](https://vwgolfmk1.org.uk/uploads/pbextract/667561/fater003.jpg)
![ThE_gOg in the usergroup ‘Old timer’ ThE_gOg in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
TG
Need your console repaired or mods done? drop me a pm
![:)](http://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/smile.png)
but can u tell me what that pipe does?
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Golf%20Ava5.jpg)
![markwon in the usergroup ‘Local hero’ markwon in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
1983 1100 C
1983 1100 C
the route goes airbox-rockercover-inlet manifold, i know the roccker cover one sucks air in, so does the inletmanifold one, whats it need that air supply for?
1983 1100 C
1983 1100 C
1983 1100 C
1983 1100 C
however it does imply that a secondary air intake wi filter would be a significant mod for not much wad
1983 1100 C
1983 1100 C
chz
I dug out this video of a car having its mixture radically altered while running. You can hear the revs rise as the car leans out (the exhaust note also gets quieter) and a little bit of fuel goes in at one stage, richening it and lowering the revs (you can hear the fuel burn with a 'pop').
![](https://i10.photobucket.com/albums/a139/paul_c2/th_MOV01218.jpg)
if i get a kn filter and add a cooler air supply to the 'dirty' side of the box , then i need to re adjust my mixture, ?
Dont bother with the cold air feed , these dont do anything unless 100% air tight . Just drill the box out with some 2"-3" holes in logical places on the lower air box ( you seem like a sensable fella !! ) .
I saw a mk1 recently with a cold air feed and a drilled air box , obviously the air feed wouldnt be doing any thing with all the holes in the airbox .
The air/fuel mixture will of course have an effect on the running speed of the engine , but there are of course adjustments that will effect idle and under loaded conditions.
Im afraid that i dont have any high res pics of a 1600 lump .
there is a small diaphram looking sensor on the front of the airbox , just try disconnecting that and see how it runs . let me know what happens !
Im sure a set up and rolling road will reveal a small problem in there somewhere and a few more bhp .
