1300cc driver - fitting a 5 speed box.
(In Topic #76015)
![duncmac in the usergroup ‘Newbie’ duncmac in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
Its a 1983 mk1.
Can this be done and what bits are needed.
Any details appriciated.
![mk1_driver in the usergroup ‘Regular’ mk1_driver in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
http://www.clubgti.com…forum_posts.asp?TID=49143
It can be done and for the chassis leg mounting it requires the need to chop up half of one mounting and half of the other, then carefully weld them together to create the required mount, cant remember what linkage parts you need and it seems as though the mount pictures from that thread have gone missing again. :dontknow:
FOUR SPEED 'BOXES!! - for goodness sake.majority of Mk2 1.3's have
Okay - 5-speed onto mk1 1100 or 1300 is a WASTE OF TIME!
However, Riley was right, you simply fabricate your own gearbox top mount as the bolts on the 4-speed run vertical and on the 5-speed, horisontal.
HOWEVER - your gearlinkage will hit the exhuast font pipe - as a result you WON'T BE ABLE TO SELECT 5th gear. Thus making the whole entire excersice pointless.
You could make your own exhaust I suppose…
Do NOT cut and weld anything on the chassis leg either - you will be using the welder on the BOLT ON gearbox top mount.
Can I just ask in your original question - why?
Oh, and, might be nice to know what Mk1 it is, 1100, 1300? Engine code, etc… These things are useful when atempting to answer technical questions.
![leroy in the usergroup ‘Regular’ leroy in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
5th gear
Its had a 'new' engine put in after the old one lost a cyclinder (volkspares refurb- but the screws for the cam cover dont all screw into anything! so oil leaks etc) and a new weber carb. eibach springs and new shorter dampers.
Bodys in really good nick as is the interior apart from the cables for the seats, going to get hold of a pair of mk2 front seats to go in.
If its really not worth it then OK I'll leave it with the 4 speed.
The bad things about the car is an after market sun roof (leaky needs a new one but as its a stupidly large size its being difficult to get hold of one) and the fuel filler neck went at the top, that was replaced, but water got in the tank and rusted it a bit, so I need to get the tank out and sort it.
Other than that its a fun car, kind of wish I'd bought a decent GTi (I had 2 ropey 1600cc gti's but they both had serious problems so go parted out) but never had the money.
I'm guessing it's an a GF engine? Might be an HK if it's a recon one.
When I got mine it was on it's original 1.3 GF engine which had been fully rebuilt to the tune of about ?800. I soon blew that engine sky high! lol
I'm running an 1100 'box in mine at the moment because it makes the car even more revvy and sprinty - absolutely flies upto 90. The next 1.3 I build is destined for my Mk1 Polo and that will be using the even scremier 895cc gearbox - HURRAH!!
![Avatar](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fwww.tt-forum.co.uk%2Fttforumbbs%2Fimages%2Favatars%2F1439242e8cb3a6d39a.gif)
![AxlFoley in the usergroup ‘Local’ AxlFoley in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
there are a few other problems that you will encounter, but these are the ones i can remember right now.
Hope this helps.
Mark
![twinturbo in the usergroup ‘Local’ twinturbo in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
TT
![retromk1 in the usergroup ‘Local’ retromk1 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![](https://i31.photobucket.com/albums/c390/ashleyelworthy/sigtrack.jpg)
Steve_Matthews said
ARGH!! - Why is the Internet full of these people with opinions?!?
its fine it will go on with standard exaust and ashley 4 branch as theres loads of room, and 4 not selecting 5th thats because it hits in teh rubber in teh gear stick surround, take off that rubber and ull b fine!!! ( under the grar stick gater))
Steve_Matthews get a hair cut as u seem 2 b pulling it out about wrong things lol
![Avatar]([IMG]http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg[/IMG])
![sim0n_parker in the usergroup ‘Old timer’ sim0n_parker in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
can it be done easily? what else can you do to it?
as i have bought a set of r6 carbs today of ebay and getting my manifold made up asap, and amlooking to do a few other little mids to it.
many thanks
simon
i always have the last laugh ![;)](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/wink.png)
<a href="
someone said add the flywheel of a polo? are we talking add the flywheel from any 1300 polo? onto amk1 golf 1300??
What difference will it make? Explain.
Hmm - bizzare - well it certainly hit my exhaust WHEN I DID IT. Obviously you've done something else to the car too which you've omitted to mention.
<a href="
![pinciflucnik in the usergroup ‘Regular’ pinciflucnik in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
more revy, but will have less inertionsim0n_parker said
1kg lighter as he allready said. this will make the engine more revy,
