Wiper upgrade?
(In Topic #75838)
Wiper upgrade?
I have heard something about using a MK2 motor?
TT
If you clean the spindles out, and grease them up (should do this every two years or so, if it's your daily driver), and then get a Mk2 motor, your wipers should be a lot better.
It should fit no problem, but you'll need to work out which wires match which on the (differently-shaped) Mk2 plug connector.
Note that some Mk2's in the scrappy aren't much younger than your Mk1, and may have tired motors too, so try to get one from a late car.
If you see a Mk1 or Mk2 one out of its car, ensure that it has a 172 or 192 part number - the 2 means a RHD-only part - a LHD wiper motor (171 or 191 part no.) won't fit.
Will have a peek when the weather is warmer …
TT
Up to '87 the Mk2 wipers are LHD anyway (even on UK cars - the wipers sweep the wrong way), so forget them if you're looking to fit the parts to a Mk1…
that may explain why when i tried to fit a mk2 wiper earlier in the year, it cooked itself. I bet it was a lhd version :roll:
Will be more cautious on the part number the next time i have a go at changing the motor. I`ve greased up my spare linkage in readiness for a mk2 motor…but it`s too brass monkeys to swap over at the mo!
But an interesting nugget of knowledge you have shared there.
Stay out of the black…
And into the red….
You get nothing in this game for 2 in a bed!
And into the red….
