I would love to see the gear change indicator going
(In Topic #72396)
Life Member
Ta Dan
No sign of needle on econometer :cry:
Suspect the connection from gearbox to loom is iffy
Anyone know which terminals connect to which?
If Its Loud and Noisy , I'll take its picture
The deeper I delve the more problems i encounter. :cry:
Suppose its all part of the fun of owning a Mk1
Dash lights first!!!
My 2 tone project!
anyone confirm? :?
if you have one…
look at your dizzy,where the vac pipe comes out you will have diaphram switch type thing.
it has a 2 pin connector and a screw in the center.
this screw adjusts when the light comes on. 8O
ive told many peeps this before,but no ones bothered trying it i dont think :cry:
neil.
ps:baz it would be at the top of the clocks,where you would have mpg readings,the light is in the middle.
if you have one that is. :?:
My 2 tone project!
