Now the fun really begins
(In Topic #224784)
Road legal at last
I guess now my car has passed the mot and I'm all road-legal the fun begins.
I went out for a spin yesterday done around 20 miles and she pulled great no issues.
today i went around 3 miles and noticed several issues.
Firstly she seemed to rev to high before going into 3 rd gear, but believe when she was warmed up the gear change did improve.
secondly, i started to hear a fast clicking almost like a relay click, from within the car and when i pressed the accelerator she started to die, there where serious lack of power, only for around 500m before i got her on the drive, she sounded fine when home but worried now, checked all the relays and they seem to be fine.
any ideas guys
There are probably a million posts on how to clean the tank out already……
ETA not sure if an 88 carb has an in-tank pump or not! But in any case…its sucking up some rubbish
Last edit: by paul_c
You dont think its carb icing do you ?
okmate said
Thanks Pal
Nope! Its above the exhaust manifold and there's a hedgehog in there too.
Unfortunately the permanent fix is to clean out the fuel tank and lines etc.
Fuel filler neck could be rusty too.
My plan is to undo the lines and inspect and blow out with compressed air.
Don't fall for the 'you just need a magnet on a string', if the filler pipe rotted its got rust, muck and water in the tank, only 1 of which is vaguely metallic.
Seeing has your car has a new filler pipe(?) and new fuel pump and starts runs stops, wait a while restarts etc These are all symtoms/attempted fixes for the above.
Check in the tank so you know what you are dealing with.
Some carburettors have a send and return. Others just have a send, but the Mk1 Golf should have a fuel vapour separator after the fuel pump, which has a return line on it.
mark1gls said
You don't need a compressor to blow down the fuel lines, remove the fuel filter and blow down the fuel line into the fuel tank (I just use my mouth) and you should hear bubbles from the tank.
I love the taste of fuel in the Morning, Right before I have a cup of coffee and a smoke….. . I usually use a small tire inflator off my 12V battery charger, and a inflater nipple….
