EARLY GTI RESTO PROJECT
Latest project......
Yomp said
tomsdubs said
Doesn't look too bad from a distance…
I'd done the majority of welding before it went for dipping. No real surprises on its return . Just a few pinholes under where the sealer had hidden it.
Now snagging the welding and removing dents followed by body filing before electrophoretic coating.
Is there a coating on it from the dipping process that stops surface corrosion? Usually I see a coating of something but that looks totally bare.
I think its been sprayed with an inhibiter as it was wet in places when it came back and by the taste it certainly wasnt water! but I'm guessing it wont protect for long
1977 GTI UHX125S
Yomp said
back from dipping…..
Incredible work and what a find! Can I ask where you got the car dipped and how much it sent you back please?
Black 1984 MK1 Golf GTI Campaign.
Campaigning for Dave said
Incredible work and what a find! Can I ask where you got the car dipped and how much it sent you back please?Yomp said
SPL in dudley. its about £1300 for this part. It goes back foranother dip and e-coat which is the more expensive part. I would add that imo dipping a shell is a last resort. This shell had a fair bit of patchy surface rust. Not bad enough to replace whole panels but it needed "digging out" to see if the surface rust was just that - surface rust or whether it went through. It has highliged a coule of areas that needed more than originally thought after intitially attacking with a wire wheel. The process basically removes everything thats not steel, It doesnt attack the brazing either.
That's great info, thanks. Would blasting have been a bit too harsh then for this project? Reason I ask is that I have a very crusty project that I'll undertake in the future and am trying to work out the best plan of attack.Yomp said
Depends how bad it all is. The last one I restored never saw a blaster or dipping. I repaired the steel that needed repairing and re coated.Campaigning for Dave said
SPL in dudley. its about £1300 for this part. It goes back foranother dip and e-coat which is the more expensive part. I would add that imo dipping a shell is a last resort. This shell had a fair bit of patchy surface rust. Not bad enough to replace whole panels but it needed "digging out" to see if the surface rust was just that - surface rust or whether it went through. It has highliged a coule of areas that needed more than originally thought after intitially attacking with a wire wheel. The process basically removes everything thats not steel, It doesnt attack the brazing either.Campaigning for Dave said
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&type=misc&id=projects%2Fyour-mk1-golfs_2%2Fex-press-fleet-series-1&start=40
People are very quick to assume that taking the shell back to bare is the only way. It isn't. Usually 90-99% of the original rubberised underseal is as good as when it left the factory and is better than anything you will replace it with.. Any parts that arent usuallly have a good tell tail as its become unsecured from the body.
Blasting still requires all the rubberised underseal to be removed prior as it just bounces off. Blasting can also distort panels. Envirostrip do a different process by heating but I've seen panels warp from this too.
Back from e-coating
Looking frickin incredible!Yomp said
Back from e-coating
Lemon Yellow Tin Top Restoration
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=your-mk1-golfs_2%2Flemon-yellow-tin-top&kfs79=30
1977 GTI UHX125S
Hef355 said
WowYomp this is different level restoration! Huge respect to you sir! Can I be so bold as to ask if you are painting it too or having someone paint it? Which paint are you using? I’ve just painted mine in VW cherry red, used Glasurit 68 line 2k solid. VW approved also and highly recommended! Again, cant wait to see this painted, it is Mars red yes Yomp?
Thanks!
I've put this one out for paint although they've let me help them so a bit more of a joint effort on this one.
PPG Solid 2K - The painter tried to talk me into clear over base but I was having none of it!! Ist shade Mars Red L31B
Yes Glasurit is a good paint - up there with the best of them.
1977 GTI UHX125S RESTO PROJECT
PPG is brilliant, especially their clear coat and i’ve heard their 2k high solid is top notch too. Good choice to go 2k solid and keep traditional
Website Manager
