02J swap, reversing light issue.
just need to make sure what you have is actually mk4 02j and not later mk5 parts
Would it be possible to just put it in and see if it works?
1983 MK1 Golf four door 1.8T 20V BAM remapped, MK2 dash and loom, TMI interior. daily.
2014 VW California 5.1 with full Sportline kit, weekend home.
If it were you would you cut the pin out of the alloy housing and use the older one (which looks in better condition) or stick with the damaged newer one?
I've also got the new parts you guys recommend.
On top of that the housing only has a bush in it and the new bearing isn't even close.
for the seal it a right sod, its metal cored so very stiff and takes a fair bit of effort to persuade it to come out. as for the bearing at the bottom you need to remove the outer bush the bearing sits in before the new one will go in. gain a right pain on these, see the link!
I'd be tempted to send it off to hotgolf/gas n gears/martin emment. he can sort it all and put a nice new solid bush in there, no more crappy bearing
Anyone see a glaring mistake ?
Not sure what the bolt does?
attachment_safe description="24617D89-FE35-46F9-B837-A5C43EADA528.jpeg" thumb="0" type="inline"]new_1
basically if it gets in the way then as above, if not then leave it be
See these 02J rods:
http://clubgti.com/showthread.php?262990-02A-box-with-02J-tower-dense-shifting
As long as the housing and the shaft work/fit together I'm pretty sure we are good to go.
I'll let you know at lunchtime tomorrow
"for the shaft pay VERY close attention to the orientation of the bumpy bit, vs the orientation of the missing tooth on the spline. the tower angles up top for the up/down linkage lever are different, so you might find the missing tooth is in a different spot".
But I followed the linky you included and I seem to have the same problem, can't seem to get to the bottom of it, the shift rod is the one I took out, the only things that have changed are the new MK4 ali housing and the TT short shifter.
Moving the short shifter without the bow connectors attached to the right (clockwise) is good from the centre position but from the centre left isn't good! And the black L shaped peg doesn't engaged with anything no matter where I turn the rod to.
Mine is/looks like this
I've now had to stop for the day but do you have any thoughts,
compared to an 02J one:
straight away you can see the selector lug on the bottom of it is on the opposite side of the ribbed section up top for the detent bolt
Where I'm having problems getting my head around it is that's the one I took out, I drove it 20 miles from a friends workshop to home after fitting the 02J 2 weekends ago!
if the missing tooth lines up to the selector lug at the bottom you will be able to get gears ok, but if the bumpy bit doesnt line up with the detent bolt you wont get a nice 'click' in and out of gear if that makes sense
It's difficult to tell really John, when I drove it the selector/gear shift was mounted inside the car and it was pretty buggered so it was really sloppy, I have since returned a newish MK4 selector underneath the car.
By detent bolt do you mean the spring loaded piece with the ball bearing in the end?
