Car cranks but won't start
(In Topic #196545)
My cabby is cranking but it won't fire. It's been sat since 2011. And I want it on the road for the summer. I have put new fuel in. New spark plus in and also got a new battery. What's the best thing to check or what should I do to get her going ? She ran fine before she come off the round back in '11
many thanks
if you remove a spark plugs and attach the ht lead and hold them with insulated pliers near the head do they spark?
veedubjay said
4 washers ? Where would I find them ? Should I disconnect the fuel line see if it's pumping past the pump
Yea worth disconnecting the line either side of the fuel filter to make sure you have pressure both sides of it.
The washers should come with the fuel filter. depending on brand. I think the Bosch ones have them included. If not just pick up a couple from the local motor factors- should only be a few pence.
You should have a fuel filter in the engine bay on the fuel line before the fuel pump (fixed to the front of the engine) Is there any fuel in the fuel filter? The filter is usally clear plastic so you should be able to see in it?
Look like this, you can get them from Euro car parts, GSF and any motor factors.
http://www.ebay.co.uk/itm/VW-GOLF-MK1-MK2-T1-T2-T25-CADDY-SCIROCCO-INLINE-FUEL-FILTER-SMALL-TYPE-A131-/190892913154?pt=LH_DefaultDomain_3&fits=Model%3AGolf&hash=item2c721ab202
If it's dirty fit a new as it's best to fit a new one each year as they are not expensive. While you have the fuel filter off blow back down the fuel pipe going to the fuel tank (you can do this with your mouth and plenty of puff but don't suck! You should hear bubbling in the fuel tank.
If you remove the air box and cover from the top of the carb you should be able to see into the carb and smell fuel if you have been cracking it over while pumping the throttle.
You could also try removing the pipe from the fuel pump end going to the carb and try turning over the engine but this should spray petrol out so best to get a little bit of hose and spray it in to a jar, if fuel comes out then your pump is working but it still could be at fault if not enough fuel is going through the system but check there is something there as it should fire up still.
How old are the HT leads, Dissy cap and rotor arm?
To test for a spark (do this before pouring any fuel about incase it catches fire!) remove 1 spark plug and fit the HT lead back on, hold it with a pair of insulated pliers on the HT lead, hold the spark plug about 1cm from the engine head and get some one in the car to turn it over while you are holding the spark plug (they will need to keep it turning over, BE VERY CAREFUL holding the spark plug with the insulated pliers as you don't want the spark to jump to you as it not good to have that sort of electric shock!) you should see a spark jumping from the spark plug if not move the spark plug closer to the head if there is no spark when you get to touching the head then that's a problem. Check the next 3 spark plugs to see if they are all working.
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf+Cabriolet_1.8_1988/p/car-parts/engine-parts/fuel-and-engine-management/fuel-pump/?339440021&1&13581b988814d2a840305c6b5b60a635c7a44d8e&000148
What year is your car?
If you add it to your profile in a signature like at the bottom of my posts it makes it easier to find out what year and sort of car you drive.
Take the pipe off going from the pump to the to the carb, (I think it's the pipe sticking up in the link?) and turn the car over to see if fuel comes out.
It could also be there is a blockage in the pick up pipe inside the fuel tank which is stopping the fuel getting to the filter so blow down the pipe back to the fuel tank and I would also have a look at that end of the fuel system and look inside the fuel tank for rust and dirt blocking everything, you can get to under the back seat.
Tried to start car and the car does seem like it's more willing to fire. However. I had smoke coming off from around the starter motor area. Obviously that's not normal. But is this something that's likely to happen as I'm cranking constantly for a few mins ? I haven't touched tampered or changed anything to do with the starter.
Is there a chance this is also knackered ?!
How much old fuel was in the car - Do you have a diluted mix of both and to what ratio?
Lots of people say that fuel goes "off". I've never had a problem, but four years is a long time…
My Build Thread
She runs ! Not only that. She has an MOT (one advisory. Number plate bulbs blown !!not bad !!
Took her in Friday. Then it rained so I ain't been able to use her. Haha.
But thanks all for your help. And see you at the AGM!!
In the mean time. On with all the other little niggles. Haha
can you please detail what you done before your last post to get the car started? Am in a similar situation with my own in that it has been idle for about 3 years and will be ready to begin starting the engine very soon. Thanks to all previous contributers too for their input regarding the fuel system checks that can be carried out.
Vonsmiggus
Ended up changing the coil. HT leads. And plugs to get a descent new spark. Then pump on a new fuel pump. And battery. With all of this I was able to get the car started. Also although the battery was new I also had my daily connected up to it to give it that boost. That all done with new petrol and oil. Got it running.
