ABF Info!
Jack
1st loom I can certainly see the engine plugs plus a lambda plug, the ECU plug isnt visible but it may be buried under the rats nest. Cant see any fusebox plugs so cant tell if its been modified for mk1 or not.
the other loom piles seem to include mk3 dash and rear looms, all with the original CE2 loom plugs on. if these were in a mk1 then he has modified it to use the mk3 fusebox, no bad thing but it may not be suitable for your mk1 dash depending on what exactly was in the donor car.
pics of the gearbox and engine mounts will confirm if its been in a mk1 at any point, if it has then it'll drop into a caddy no problem
I can't recall there being any mounts on it, though there may be some in the pile! Its a shame the instrument cluster doesn't look Mk1, because I really like the features of the Ibiza ones!
Jack
easy to get the original mk1 dash to work with the abf if you prefer, or mk3 etc up to you
http://www.clubgti.com/showthread.php?249714
you'll need to add a fuel pump pin into your rear loom E/14 with 2 wires one to a male spade and the other off to the pump +ve. The male spade is then used for the ABF injector and lambda heater power.
If you have pro terminal tool you can buy these pins new, if not you could find a spare CE1 loom and hack out the pin you need.
I can do this all for you if you like, my waiting list has dropped down quite a bit now as several people have dropped out
Jack
then it should be the same job as if the loom was fresh out of a mk3, just without the tape stripping part!
once the engine loom is done you'll have to add the fuel pump power as above plus swap the 67 relay into your old fusebox.
When I come to put it in, will I be using this Mk3 fusebox or the one in the Caddy?
Jack
Jack
The mk1 fusebox is perfectly fine I've done many abf -> ce1 conversion looms
Jack
