Door Seals
(In Topic #233844)
New door seal installation
How should they be attached? I'm assuming they are glued but what product should be used?
Thanks in advance
Max
Probably what the last guy did but you do need to use it as described on the tin or it will fail, basically thin coat both surfaces and allow enough time before application, and it's a one chance thing, you can't slide it or pull off and re-position.
