Electric Widow Module 191 959 875
(In Topic #232258)
Red-or-Dead said
Hi all, before you say I know this is in the wrong section but getting peeps to respond from the “ breaking a car section” is really tough. If anyone can help I’m after the electric window module for a 92 Clipper 1.8. There’s some on eBay but there either mega bucks or no one is able to confirm if they work. Been after one for ages. Hope you can help.
Wrong section…… you need the scrap parts section.
There are a few on ebay at minute from 50 to 150 , new from zee-germans is 300 with tax and shipping.
https://www.ebay.co.uk/itm/274486711660
On the drive
Myvalver 89 GTi Grey mk2 16v
What, Other issues?
Well I would ask if you have a/c installed and a large fresh air plenum?
If the answer is yes, then I would remove the Fresh air inlet and replace the foam seal that is under it and re-install.
If you don't have that then I would also suggest re-routing the hoses out of the Rain Tray (scuttle) Rubber, and cleaning both rain drains.
I would also install a screen over your bonnet air inlets to prevent debris from getting to your rain drains.
And or rust around the windscreen allowing water to drip on to the wires of the controller and into the unit.
From what I have learned over the 14 or 15 years of Cabby ownership I have seen that water migration through plugged rain drains cause water to back up and into your cabin via the air-plenum seal.
If you haven't removed your controller and disassembled the case from the PCB and look for cold solder joints, and or dirty contacts on the relays you may be want of something that a little work will fix.
Homemade window controller:
Home made power window controller for 90 something cabby | VW Vortex - Volkswagen Forum
Cleaning and resoldered made a difference:
https://www.vwvortex.com/threads/power-window-controller-92-cabby.5017522/#post-67461930
Homemade Debris Guard:
http://www.toplessrabbit.com/forums/viewtopic.php?f=27&t=1509&p=27750#p27750
* Every Thing that you wanted to know about power windows in a Cabriolet but were afraid to ask?
https://www.vwvortex.com/threads/a1-cabbie-power-window-problems.2126843/?id=2126843
Re:
AirCon I bet you can count on fingers of 1 hand how many golf mk1 to mk2 had that installed..Briano1234 said
I would take care of the other issue prior to putting a new controller in.
What, Other issues?
Sent from my SM-G960F using Tapatalk
On the drive
I know the biggest issue I have seen is water migration into the controller, and that is usually plugged rain drains and water infiltration, or cold solder joints. A/C or not, the cause and effect are the same.Kenneth Cartwright said
Whip
/wip/
Noun - Car
/wip/
Noun - Car
On the drive
They don't look shiny silver but dull gray with a ring around them usually.
Here is one on the controller that was de-soldered and cleaned then the relay functioned correctly.
The controller is the Same on a 2 Door Golf up to 95, and or Jetta, and passat.. The 4 door may work, but you would have a couple of extra relays for the rears.
The latter Cabrio 95-2000's have the controller on the motor, and it is a totally different ball game and doesn't cross over.
Red-or-Dead said
Thanks for the advice guys, although it kinda swerved off topic for a bit
Well I wasn't off topic, I just gave you all the information that I know of…. Granted the one link on EVERYTHING was 6 pages long… but it was everything I know of….
Red-or-Dead said
It’s a closed module. I need one of these.
Seeing as it doesn't work and replacements don't exist I'd be attempting dremeling it open and see if its duff joint or replacable relay
It’s just startling to make my wee fizz. Been trying to pick one up for a year without shelling out the mortgage money.
thats £24 … take a punt…
£29 this one https://www.ebay.co.uk/itm/202839753301
Sit back and think how many hours you think and "waste " talking about something….. the minimum wage in the UK is £ 8.72… in 4 hours worrying and typing you will have paid for a part If it doesn't work you may have the parts to rectify the other..
When you take your car for a service…..any car new or old
you are paying minimum £40 per hour for diagnosis and then £25 for plug in service reset,or stamp in book.
Specialist refurb shops charge upwards of £70 per hour so you could be looking at a bill for basically diagnosis of faulty module of 160- 280£ before you start, given you said taken the door cards off, window motors /regulators out cleaned and checked function. Checked wiring to module and motors.
So think to yourself that you've saved 200£ plus by doing the work yourself so spend on a ebay unit.
As for the ebay comment maybe the seller, can only say came from car that was working…. and as such his/her guarantee can only be was working. If they go find a car with wiring or running and try it for you then i would personally bang price up myself for the hour.
But take a punt, look at briano123 post, or go find someone local with vw with electric windows and use the disassembly access knowledge you've acquired to pull out module and try it.. Obviously you have to guarantee you want damage the other users car in the process. Theres plenty of members in each area.. I myself have 3 cars with modules, you only need to come over and try… ill let you loose on a rocco.
Not ranting or wanting to cause any offence..
On the drive
