Help sourcing 90mm cups
(In Topic #223850)
Looking for 90mm cups.
I detail that in my how too on replacing the differential seals in the signature link. If you have a good Breakers about you may find them there.
IIRC the circumference of the rear shaft is a little over 11" for the 90 if it over 12" they are 100mm.
see: 020 Flange
I have read the how too's and many other threads regarding this which have some great info. Unfortunately sourcing the cups seems to be another matter. Can I just confirm that if I get the newer 90mm cups I can swap them out to replace 100mm ones used on the 020 box, meaning I can use my original shafts with the 90mm cv? Or have in misunderstood all I have read? Thanks.
The Cups are the only differences between the 90mm 100mm. Differential output shafts are all the same so the 100 or 90 cups will fit all the diffs of the 020 or 010's.
The Spindles are different, the 90 shaft will fit into 100mm spindles. However the 100mm Shafts will not fit in to the 90mm spindles.
Last edit: by Doom
