VDO GAUGES SENDER
(In Topic #223011)
The above is for the oil pressure, the oil temp is a black single pin gauge that is on the oil filter flange.
They are the low pressure at Idle switch, and the Oil pressure sender.
The Blue/Yellow wire is for the oil pressure, and the
Normal one that is connected to your low oil pressure at idle sender connects to the other. usually yellow
