Big Vee's cab project
(In Topic #220348)
Just about stripped down
Last edit: by Big Vee
GBone, I just used some spray window cleaner then used a clean white cloth with a stick to move the spray about, be careful not to tip the lights as you don't want to damage the reflector surface as this is very delicate, My main headlights are damaged so I am not sure if this can be repeated I.e. remove the bulb holder from light back, I've binned these so unable to give a definitive answer sorry. I have ordered two Hella lights from classic vw £75.00GBone said
Hi, those headlights look bob on mate, what did you use to clean the glass? Anything special? Iv just picked a single headlight grill up for mine and the headlights are cloudy like that. Can I use the original lights in that grill or do I need to use the ones that come with it? Sorry if that's a stupid question, although its not my 1st vw it's my 1st golf.
As to your lights I suppose you can use either if they look the same and mount to your front panel "think that makes sense" ??
I'm liking what I'm seeing!
Especially the design of your car rotisserie, nice and simple.
If you designed/built it yourself, I'm sure there's lots of members who'd be interested in the design specs.
As a '93 Cabby owner you've my attention!
ConvictGTI-No.1983EW said
I'm liking what I'm seeing!![]()
As a '93 Cabby owner you've my attention!![]()
Thanks Convict, The rotisserie is borrowed of a mate who used it on the original Audi Quattro model, he did purchase it of eBay though. Its made life so much easier than crawling under the car. Lots of work as it looks like its going to be a nut and bolt restoration.
Keep the updates coming.
From a simple refurb to now a nut and bolt rebuild !!!! am I going to far with it or not ? the only thing I'll have done for me is the new roof covering
