D t a
(In Topic #220793)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Avatar1554227280.jpg)
![BradleyB in the usergroup ‘Regular’ BradleyB in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
2.0 9a engine
My cars not starting and I’m out of ideas
D t a
I’m unsure what version it is
il get some photos of unit and see if I can work it out
Do the ecu ever fail
The car seams to be doing everything apart from starting
I have fuel and good spark
Just changed plugs , leads , fuel and still the same
D t a
I ran out of fuel and then it won’t start again
on the fuel side does the ecu trigger the fuel pump ok? maybe check you got good flow to the rail. do the plugs smell of fuel?
D t a
I thought similar and changed crank sensor but still no joy
So I’m looking for replacement coil ASAP
Il let you know how I get on
Thanks so much for advice mate I’m going to give it another go this weekend
D t a
D t a
I changed it to be safe but no result on it starting
This is why I just wanted someone to plug it in and see if it reads any obvious faults
