m
my mk1 blue cabby project
here we go .....
Kingy76 said
Great progress made once again, the car looks sweet in the sunlight with the roof down, it’s great you are putting right previous wrongs so you can really enjoy the car and some pics of the dials once plumbed in would be good to see.
Thank you yeah I’m sure there will be plenty more photos to come , I can’t believe it hasn’t set fire yet due to all the dodgy wiring
Going to finish the floor tomorrow
Started to clean the dash and dash parts and air vent ducts as the weather was nice
Look at the state of that water
My delivery guys really don’t like me at the moment
. New callipers on
.Rear foglight on
.lots of little bits finished
.reverse light switch fitted
.new Horns and horn loom
. Gauges mounted in my new centre console
. Oil pressure sensor fitted
where did you source your brake callipers from, so many out there at quite cheap prices but I’m unsure if the quality is any good?
Kingy76 said
Great work, like the old school plates, suit the car well. Look forward to seeing your gauges wired in and lit up.
EBay item number 263759057429
They seem a lot better than what I had
I think I’m going to run the plates if I feel brave enough
The photos will come
Keep the plates, very cool.
To wet vac my cars seats and carpets while there out
Even got the seats in the daily done be rude not to right ?
As well as bonding the dash back together as it was in a poor state of affaires
Got the rear interior back in and handbrake back on
New gear stick test fitted
And I've ordered up a new 85mm filter king regulator and facet red top pump ?
As the last owner had 10mm pipe from the pump too the original 6mm car fuel lines right next to a manifold
Also got the window switches into there new home , just need to wire them to the ignition live instead of the permanent live that they was wired up to !!
If I was to have a accident it would be the first thing to brake and set on fire
Also need to find a new instrument cluster as the battery light don’t work so the alternator isn’t kicking in properly
AT WHAT PART DO YOU ACCEPT DEFEAT
Kingy76 said
Don’t give up, your attention to detail and effort will be rewarded when you enjoy driving it during the summer months and you’ve had really positive comments so far and your progress seems pretty swift so keep going, I for one am looking forward to seeing it completed!!
Thank you for the uplift , been a very emotional drain one step in the right direction then 10 back fixing all the poor workmanship ,
I’ve learnt not to judge a book by its cover now
