mk1 caddy 1.8t conversion driver shaft
(In Topic #220416)
![Harley26 in the usergroup ‘Newbie’ Harley26 in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
100mm driver shafts
so my Question is can i use my mk1 caddy drive shaft with 100mm cv joints or do i need different drive shaft
![IMG_2304.JPG IMG_2304.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1552224215/uploads/attachments/5c850fd677d71.jpg)
I will tell you that if you had 90mm axles originally or what is equipped on it at this time, then the 100mm Axles will not work on 90mm Spindles (rotor/hub).
The 100mm Spindles off of a latter Cabriolet will go 100 or 90mm without an issue, the issue is that the 90mm spindle will not go to 100… There may be a way to do it but you will have to grind the 100mm axles down.
On the Standard Trannys on a Golf/Cabriolet there were two types of axles 100mm on latter Cabbies, and the 90mm that were more prevalent.
And swapping 90's in place of 100mm was simply finding 90mm cups on the differential, and swapping them over with the proper seals.
to fit into the O2J gear box which are 108mm flanges
my driver shaft are 90mm
i just got offered mk2 golf gti 16v 100mm drive shaft they fit in the mk1 caddy hub but guess they are too long
![cups.jpg cups.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1552234258/uploads/attachments/5c8537112e065.jpg)
https://www.classic-vw.co.uk/mk1-golf-100mm-driveshaft-set-caddy-scirocco-20000-p.asp
Regional Host NE
after mate
Regional Host NE
![shafts.jpg shafts.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1552291711/uploads/attachments/5c86177d6e471.jpg)
That what I keep seeing to Fit the the 1.8t and o2J gearbox
