Alternator Voltage regulator upgrade
(In Topic #219181)
that kicks the alternator up by .5v
Since the VW alternator is inheritable weak, if you have not the perfect grounding and wiring, then your battery will not charge properly.
I did this on both of my VW cabrio and the voltage went from 13.5v to 14v
I tried to find another thread online where this was described, but I couldn't
Just make sure when you do this, to
a) put the Diode in the proper way. (diodes are a one way valve and won't work in the wrong direction)
and
b) cut the ground wire after soldering in the Diode. Or cut the ground before but make sure the path goes through the diode and not bypassing it.
Re-volting idea for regulators. | VW Vortex - Volkswagen Forum
Good Work Allmacs Every little bit helps
