handiman42
(In Topic #216483)
![handiman42 in the usergroup ‘Paid Member’ handiman42 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![handiman42 in the usergroup ‘Local’ handiman42 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
fuel problem
![](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/chess.png)
I know it's for a MK2, but there's enough similarity and Jonny's guides are useful for checking that you've not missed the obvious
I read your first post and thought fuel pump relay for the noise inside the car - maybe that's given up?
When you turn on the ignition you should get a little, quick buzz from the pump as it primes. To test that's working you could as you say disconnect a pipe and turn the engine over. I wouldn't disconnect the 5th injector hose just on the off chance there's any issues with that working as it should - or by off chance you warm up the engine enough with your testing and then the 5th injector should prime anyway.
The easiest way to test the pump would be to put 12v directly on the pump - just be careful with the risk of spark/fuel combo!! You could put 12v on it from the battery without disconnecting any fuel pipes just to see if it buzzes. If that comes on every time then I'd be looking at the relay.
Do a search on here about bridging the relay. I can't remember which two terminals it is but you can take the relay out and put a bridge in two slots on the fuse board.
Be careful as that will run the fuel pump 100% of the time. However, if you do that and run the engine and it runs fine, then the relay would be the likely culprit.
Hope that helps!
