Found this !
(In Topic #215909)
All I've done in the engine compartment is remove the old loom and install the new one, no mechanical stuff.
A MK2 dash has gone in as well be this was under the car.
Any thoughts?
1983 MK1 Golf four door 1.8T 20V BAM remapped, MK2 dash and loom, TMI interior. daily.
2014 VW California 5.1 with full Sportline kit, weekend home.
Interior Parts.
I've just thought, I took the windscreen wiper motor and mechanism out to replace with a MK2, could it be from there?
And if it turns out I really did need it, it will make itself known.
Raul said
When things like this happen to me, I put them in my 'I didn't really need that' box.
LOL as long as it's not engine mounts or wheel nuts.
https://www.volkswagen-classic-parts.de/en/kegelfeder-98bc75.html
Had any other classics on the drive or in the past?
The part that is white on the right is what I was referring to. it is inside of the unit to apply pressure between the white outer case and the inner vacuum diverter rubber bit
When I installed the MK2 dash the MK1 heater control wouldn't fit so I purchased a MK2 unit (as per your image) and installed that.
The only other classic on the drive recently has been the wife!
installation kit…
I just used wire ties, and foam covered washers when I did my external oil cooler then foam on the front Valance supports.
Worked just a well, and easy to replace, but I haven't had any issues and it's been installed since 2008
