BAM engine loom and plugs!
wirign looks ok apart from you have missed off an earth in last photo. if its for the ecu, thats probably why no fuel pump prime as its ecu controlled
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/20160228_142150000_iOS.jpg)
![Pete M in the usergroup ‘Local’ Pete M in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Should the pump do something if I put a direct connection from the battery, because it doesn't.
I'm guessing there is something amiss as there is no power on the red/yellow that is the supply from the board,
1983 MK1 Golf four door 1.8T 20V BAM remapped, MK2 dash and loom, TMI interior. daily.
2014 VW California 5.1 with full Sportline kit, weekend home.
The earth with the ring connector in the image has a spade at the other end (which comes out of the new loom at the fuse box) so it's a metre long piece of cable that does do anything!.
the fact you get nothing from pump when jumped from battery suggests its buggered, take it out and have a look!
I have the main supply from the battery in Y3 and that's it, the red/back from the ecu loom in Z1 and a new fused cable from the BAM ecu loom in Y2.
I get 1.75 volts when I turn the ignition on across the red/yellow and brown.
fuel pump wise if you have jumped the lifter every which way with 12v and its still not doing owt, its dead. take it out and have a look
![image.jpg image.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1514987901/uploads/attachments/5a4ce17a5a0b3.jpg)
![image.jpg image.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1514987905/uploads/attachments/5a4ce17fee138.jpg)
I only get 1.7 v across the red/yellow with ignition on or off.
Have I got the supply to the board correct?
with the lifter now you need to chase the 2 wires from the pump, check which pins they end up on the outside. the live pin will go direct to a pin on top, the earth pin will be common to the pump and the level sender, level sender pin will go straight to the last pin on the plug.
jump the pump with 12v straight off the battery, see if it does anything (watch out for fuel spray
Left pin (yellow cable) is the earth and the centre pin (black) is the power and the pump hums away nicely.
I'll check over the connections at the relay etc but the board/connections are mint condition.
So does that mean I've got the supply to the board incorrectly wired?
the 17/18/100 relay is trigger feeds are all direct from the internal fusebox ignition and earth rails, so as long as the ignition switch and wiring is good as well as the main earth that side is fool proof. the main live side is fed from the big 30-30b jumper which I can see is fitted so thats all fine too.
its possible fusebox has been water damaged, my fuel relay socket was a bit poor due to this, eventually the fuel pump fuse melted as well
Now to see while it won't start !!!
I am so grateful for all your help yesterday. Now to tidy up and make good all the temporary connections on that side of thing before I start on the headlamp loom connections.
DIAMOND GEZZA
![:cool:](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/cool.png)
I've got the MK4 alternator loom so here goes …
alternator is easy peasy, 1 wire from mk4 to blue on the mk2 loom near battery
I've just had a look at the connection on the tailgate and there is an earth (guessing as it's brown) with a female spade terminal that isn't connected to anything.
I've got the MK4 loom in front of me, there's the main large positive cable and a 4 pin D and 2 x 2 pin D's 1 with a pin female insert and 1 with a black insert, both have black heat shrink over the wires, what do I need from it?
