warm up regulator
(In Topic #195585)
the mythical creature
In my quest for the perfect running engine, it has come to my attention that on warm up and initial cold driving the old girl is like driving a bag of spanners!! When warm no issues.
I've read lots about a warm up regulator, or "cold start" valve. However when I call parts supplies I may as well be speaking French.
So does anyone know a part number for the unicorn, sorry, warm up regulator!
Depending on which engine (DX, EV etc) you could check this link, (for item 21):-
partsbase.org
However there may be other reasons, including checking the cold start system, item 28:-
partsbase.org
You could also read Rubjonny's article which (although written for a Mk2) covers most of the points for a Mk1.
Good luck! There are various causes for the symptoms you give, so I suggest you have another go based on the above. If you've no success then I suggest you post again in the hope of getting wiser heads than mine to guide you.
If you are interested private message me 👍
I was keeping them as spares but will sell them if it's helping someone.
Last edit: by Massbad69
lhasa green 83 gti tintop MOT passed Aug '14 after nearly 12 years!
Audi A6 3.0 tdi Avant Quattro Le Mans 305bhp
paul_c said
Don't think that simply replacing a warm up regulator with another will solve the issues. Any WUR fitted, needs to be set up properly, in fact I bet yours isnt set up properly but still works. Garages have probably forgotten how to do it now.
I'm going to remove and clean my warm up reg tomorrow as gtis running a bit rough from start up checked and set up every other component on the system
how do you set up the warm up reg hope you don't mind me asking
you'll probably need all the basic idle and co settings reset though if its been tuned with a bust wur
