What you planning to do to your car tomorrow?
(In Topic #212068)
General waffle
Sportline yuppie flu….new to me..supersprint exhaust system… fitted. I hope.
Hopefully that will free some power and noise… like a boy racer.
On the drive
Myvalver 89 GTi Grey mk2 16v
Deandubya said
Seriously on a Sportline? KC nooooo don't do it.. next you're gonna be getting a turbo rasp on your back box when you change gear lol
Deanduya it's got to be changed anyway as it's rotting away. So…with that in mind I was looking for more subtle approach but this turned up inclusive of manifold.for price of back box alone. So will give it a try..if it's too much I'll change the back box later..im not cutting the spoiler/ bumper.😎 the snowy I will look at seat trim again. Unless you've got a couple of bits to try against.
On the drive
On the drive
As for the white.. I got the dotted line material but not the square…
Stealth mode is more active on my 330d… brum brum whoosh….
On the drive
Kenneth Cartwright said
All noise and no go….stealth mode not required here..where bikes roam with deristricted pipes. If it's not cows or crows you hear. It's bikes or r32s coming from lincoln way. Pop Pop pop no whoosh.
Being chased out of Sherwood Forest?? Lol leave the Beemer to the wife.. sounds like it'll be safer
Will get vids of noise and sound later.
Just need to find out earth or something with wipers..
On the drive
Cold and then after 5 mins warm up…
On the drive
Checking outer seals , lamps ,handles , alloys, visors all fitted and accounted for. Snowy is ready for paint shop.. well almost 1 nearsside b pillar seal required.
On the drive
Well I'm done for today. But tomorrow is new day. So let's think and plan ahead.
Be sure to wrap that header with heat disbursement material or Make a Heat shield out of Aluminum to shield your steering rack and Axle boots, as the heat will distort soften and weaken the axle boots (I know from first hand) for the steering racks I have seen it run the grease out of the racks and on power steering racks I have seen it ruin the o-rings causing the racks to leak.
Over here on this side of the Pond I have the same type that is getting ready to be installed on my 93, after the "last" emissions test. I currently have a tt tuning dual down and a g60 manifold on one, and a homemade dual down and g60 manifold on the other, for both of them I had to make a heat shield.
my 2p.
The sportline is just having some coolant checks..and searching for bad earth. Temp gauge very hit and miss. Still waiting for b pillar seal from Germany.snowy may get a replacement rear light cluster. As bulb holder keeps falling out. Lol.
Still waiting for a JH loom to appear from thin air.
On the drive
On the drive
Well I was glad for a "mono-wiper" and Rain-ex on the windshield. Got home tightened the nuts all is well.
I know that feeling my one did it to me about 2 months back. Then the other day just skipped the blade and scratched all my screen. Joys of old cars. We will get there.Briano1234 said
I don't plan on wrenching any time soon, yesterday I drove in a torrential downpour, and the passenger side wiper decided to loosen and stop working…
By the I plant to drive mine tomorrow to the AGM and then drive again on the rally. Come on sunshine â~€ï¸ give us a boost I haven't fitted my door seals yet
On the drive
Still got there though. I am trying to get the mrs and kids in gear…Kenneth Cartwright said
Well made it to AGM but seem to have lost 5th gear. So will try see if can see a bent rod. Then hunt my parts for spare.
5th is a splash oiled gear, if the qty of oil is low, then 5th gear doesn't get the proper lubrication and burns out.
Yes it can be replaced on the car, or out of the car.
Read more about it at www.brokevw.com
(Yes I hate to be a kill-joy), while it is possible that it is an adjustment thing, it usually isn't.
Briano1234 said
5th loss is usually a low oil in the tranny thing.
Hi
I'm sure tranny/ box is fine..as was working ok. I did a part bush linkage change last summer. But looks like the circ clip came from slot on gear stick. And then garage worker kept pushing to find a slot..🤐 still got to AGM ok.. so will change what I can and hopefully 5th will return. Have 1 set to change on my white cabby as is loose…but will sort sportline 2nd..that way I still can enjoy summer.
On the drive
3 x moving cars… tax and mot.
1 x castor on drive
1 x myvalver still in paintshop.
Picture of 2nd Dunham AGM.
Last edit: by Kenneth Cartwright
On the drive
