Kr overrun valve set up
(In Topic #211891)
the over-run valve is bigger and plastic, with yellow/black and brown/black wire. it should be connected between a pipe on the rear of the airbox and the rubber boot or plastic pipe, depending on the combo of mk2 bits yopu got as they changed in 1990.
note the over-ruin will only work if you have wired in the isv control unit
