Saulty's 1983 Tintop 1.8GTI
Once I had got the angles correct and welded I ground down the welds with a dremel and then cut it to shape so that I could but weld it to the existing skin and then zinc primed it
I then welded the new section to the existing skin and ground down the welds with the dremel. That took some time as well.
I then cut the new section to shape, I made a mistake here by cutting it in a straight line rather than to the line curved line of the doors original shape, this became obvious later when I folded the outer skin around the inner.
Once I had welded the new section I folded it around the inner skin on the leading edge and put a generous amount of sealer in there and then ground down the welds.
Then I removed the old stripes and paint all along the door bottom and filled ready for paint! I seem to have been slack on the photos when filling as I don't have any. I also hate it and I'm not that confident in doing it.
Then came the rattle can spray job!
All in all I am quite pleased with it. The line of the leading edge is too straight and the rattle can spray job is not the best but hopefully it will hold out and look good once I have the stripes on! I also gave it a very generous amount of cavity wax to help protect it from the inside!
Well impressed!! What filler did you go for in the end and did you get a long sanding block?
chrisL , Everything below the swage line is rattle canned, on the leading egde I also went above the line by a few inches as that is new metal. It's easy to criticise your own work and I look closely and see little bits that aren't 100% but I intend to restore the car one day anyway so it will be getting a full respray when the time comes. I got theh rattle cans from Halfords, Mars red no2 and, believe it or not, they are reasonably priced!
Onto the drivers door next!
Here's a pic!
Hairyarse said
Tidy job. I agree that you want the bracket there. Having the scuttle flexing due to the motor can't be a good thing
Thanks Andy, i know others have left out the bracket but there was quite a bit of movement and I just wouldn't have been happy driving it too far with the motor swinging about on it's mountings.
Going to attempt a few more pics in a minute!
Cut out the rusty metal…..
…..and cut to shape and welded to get the right angles a repair section for the inner skin I made when I did the passenger door and welded it to the inner skin.
When I did the passenger door I cut out the old metal to a line parallel to the swage line but when I welded in the repair section I had a bit of heat distortion in the swage line which was hard work to get right so this time I cut at an angle to get as far away from the swage line as possible. I tacked the repair section into place and refitted the door to check the gaps and then removed the door again to weld the section in fully. I then re-hung the door again before the sealer went off between the inner and outer skins to check the gaps.
Then it was time for some rattle can paint!
And then the passenger door!
Ratlle can paint match looks good too - not easy on red.
Happy days
