Abf. Killing me 😡 Running hot
(In Topic #206718)
got my bigger 40mm alloy radiator fitted with twin fans
was only running 5 mins before boil over even with single fan running
now it runs 1 hr ish before boiling over not tried on road
it's fitted with kenlowe fan switch which is ajustable temp
temp at boiling gauge is half way and according to fan switch 85'c 😧😩😩
but turn fan switch down so fan cut in it does drop temp gauge fans drop out
but can feel air in top hose bouncing on idle over flow pipe to header tank water is spitting not constant running unless put revs on
but then temp goes back up instant
I have just removed thermostat not tried yet letting cool off before trying agin
Was just the 16 gti radiator
No signs of it mixing
Hard to tell if using water don't want let get to hot
Or I would just pulled head off
I pulled water pump and housing off engine
All good plastic blade type but still all good no blocks
My last engine in car done this when fitted but that was hole in engine blocked were water pump bolts to block
