rear brake regulator, mk1 gti tin top
(In Topic #203283)
do i really need the regulator if i am sticking with drums?
Does your 's look like this?
More Weight More Braking needed. Less weight the less braking needed.
Proportional valves on the Cabbies are on the MC.
Rabbits had them at the rear, or off the fender where the 2 lines are off the mc going to a distrubution/valve block.
They had this on a few cabbies, but I don't think one in the rear is needed…
I had some on a Mini-van I owned, and I had to replace the rear leaf spring to replace the valve.
On my Rabbit Diesel I had 1500lbs overload springs to prevent the rear end sag… and I only had the proportional valve at the front…
I never try to re-design the braking systems…they were made that way for a reason.
Brakes are the number 2 safety feature of the car, the way you drive is number 1.
Briano1234 said
They are proportional valves that use the spring weight or action to increase or decrease the amount of fluid that the rears use for the wheel cylinder to operate the rear breaks, and to stop the brakes from locking up.
ok thanks
If you are not sure what you are doing with brakes its best to have a good garage have a look.
So I think that using the Valves off a Cabriolet would work fine.
As they are similar to the picture above but located on a different MC in a different position. I don't know why you couldn't take the lines and MC off of a breaker cabby and graph them on to your ride.
My 81 only had 2 lines out of the MC, going to the Proportional valve located on the lower fender.
I didn't have a load sensing unit on my 81ls at all.
I do know they weren't installed on latter years so it may have been a one time thought about when the CADDY's appeared on the scene…
I have had rear brakes lock up, it isn't fun…. but I can laugh about it now…..
If you do fit a Mk1 cabriolet master cyinder with the regulators fitted you may need to change the wheel brake cylinders in the rear drums as I believe they are different.
http://www.vwspares.co.uk/g1brakes.php
On my cabrio 16v I made a bracket to allow the use of a mk2 golf regulator as the mk1 units were very expensive at the time and I happened to have a new mk2 one in my bits box.
I used it with rear discs though and removed the regulator thingies which are near the chassis leg as mk2s never had them. Not sure if the valve would be ok on rear drums, mk2s had the regulator on bigger engine carbs with rear drums though so I'd assume its ok
All I can say is the VW way they have the adjuster is oh so nice… easy to install and easier to adjust..
Briano1234 said
I will tell you flat out that all the different types of rear brakes I have ever changed, and that is a lot of differnt makes and models, the worst were my inboard rear disks on my rover.
Cheers. gonna have a think on it.
Been reading lots of these posts the last few days.
my rear brake load valve is completely seized up.
Cant find a replacement .
Need to upgrade to the mk2 version like
rubjonny done here:
https://www.clubgti.com/forums/index.php?threads/custom-mk1-bracket-for-mk2-bias-valve-update-bracket-made-oppinions.186900/page-2
Can anyone suggest getting the bracket made up?
else can i use the inline ones that fit on the MC directly?
If so what is the psi or ration i need please?
Mk1 golf GTI 1.6 1981
Cheers!
or you can use inline cabrio/rocco versions
Did the brake lines need to be changed or did you get away with bending them ?
what you think on getting these
https://www.bks-tuning.com/vw-golf-mk1-pressure-reducer-g60-16v-vr6-brake-pressure-regulator-brake-pressure-reducer.html
Was thinking bypass totally and wack them on the MC between rear?
thanks!
edit:
inline cabrio/rocco versions are what i have posted right?
Yeah the old lines are fine to re-use, you'll probably have to redo some of them anyway though have a look. my line over to passenger side was shot, the exhaust bakes off the paint
those inline valves would be ok but pricey, could probably find a mk1 valve for similar money. 1.4 mk3 golf uses inline valves not sure on the spec but if you go bigger up front prob do you fine
part number is this: 533 612 151
(i have drums on the back)
