Help with Gearchange
(In Topic #198584)
I am having problems engaging first gear and cant fix it myself.
Dont know where to go with this..
Do u think it might be an adjustment issue? I hear of 'adjusting the spindle' whatever that involves….
Tabbi said
I have fitted that exact kit but the round bit for the gearstick wasnt a great fit so im.still using the old one which has alot of play up and down.
Tabbi If you look under the car and starting at the rubber boot beneath the gearstick, there is a steel rod going towards the gearbox. At the end of that rod, there is a bar clamped to it, if you undo the clamp and pull the bar off, you can move the position of your gears in relation to your gearstick……….this is only useful if you can only get 1st gear by pushing down on the gear stick to to get past the reverse safety gate.
NOTE: if you do undo the clamp, clean it and MARK IT with something beforehand as it helps knowing where you started at, takes a few attempts to get right
