2.0 16v vacuum lines..
(In Topic #194233)
So, I had a 1.3 driver and now it's slowly becoming a 2.0 16v (9a).
Block is in and wired up, but I don't have many of the vacuum lines and I'm wondering which ones I need, where to buy them from, and more importantly.. where do they go
any help would be great, thanks!
I have a crankcase breather which doesn't seem to connect to anything on the air intake?
I then need the hoses between the servo and manifold- but not sure where else they are supposed to go? does they connect to each other? Haven't got a diagram :/
you then have the chunky hose to the brake servo, theres a pipe here from your mfa clocks if you have them, plus if the 9a ecu has a vac nipple on it you need a pipe from here for that too. Apart from that the nipples can all be blanked.
you may have some nipples on the intake boot and/or throttle body all those can be capped off, the inlet boot ones will be for the warm air feed on the airbox if it has one which again does sod all and the others will be for random valves and carbon canister non of which you will have
Thanks for that john, I will have a look next time I get chance to look at it again!
