Dash lights doesn't work when engine is on only work when engine is off
(In Topic #188505)
drove the car for the first time in the dark last night.
dash lights are lovely and bright when engine isn't running. Soon as I start the car they go out, only the clock display stays illuminated .
bit confused on this one
thanks Adam
put key in and still work
soon as I turn the key and start the car the dash lights go out. I've checked all earths in the engine bay, behind fuse box - guessing it could be behind the clocks? I'm puzzled
could you explain a little more still trying to get used to the car? Eg where is pin p
sorry in advance
adam
took the plastics off. The solid grey wire goes from ignition but to the stalks - any other suggestions?
I'm really confused on this one it's likes it been reversed lol
adam
do the sidelights work still with the ignition off? also do your plate lights still work when the dash lights go out? If not I suspect the light switch itself has failed somehow.
If the plate lights work ok next up get a bit of wire and stuff it in the back of the switch between the grey/green wire and the grey/blue pins. Since both the plate lights and dash light dimmer wheel are fed from the same feed inside the switch, if the above sorts the problem again its got to be the switch somehow, a random failure to be sure!
sorry for the delay. I got a replacement switch as I had a donor car for a while, changed and still the same problem.
Dash lights only work when ignition isn't on.
cheers again
any more suggestions? I'm wondering if it's the clocks?
Thanks again
adam
Sorry buddy about this problem
going to be a clock pcb issue or maybe the earth to the head is bad if its an mfa cluster. its brown/white to the side of the head. also on some theres an extra braided earth from head to one of the coil mounting bolts that can help
