kamikaze cabby's latest ebay purchace..... hehehe
(In Topic #187162)
lol…. seemed like a good idea at the time so I worked a deal with the owner and bought her up…. hehehehe
and I must say I recon I got quite a good one there are some bodywork issues (dents no rust at all from what I can see!)
nice spec as it has power steering and also central locking, all in all quite chuffed as it didn't cost that much!
now the fun begins as it's been layed up for almost 4 years so needs a bit o' TLC
1992 clipper…….. "THE BLACK ONE"
1990 mk1 caddy…… " THE PIKEY WAGON"
1969 type 3 notchback
Last edit: by kamikaze cabby
hahaha
fixed the bonnet release coz the cable had popped out, and started to strip out the interior for cleaning..
tomoz I am gunna strip out the carpet and jetwash it as it smells a bit and no matter how long I hovered it earlier there was still more sand and dirt in it!
Calummk1 said
Bet that hasn't got a yellow engine haha
nah…. funnily enough it ain't, instead some plonker has painted everything black so I am gunna have to sort that out as it looks shocking! hahaha
this one is just about double the mileage of ma gti at 140k but as it's a clipper it will be a bit cheaper to insure and at some point I may instal an lpg kit which will make it stoopid cheap to run!
Melteddrummer said
Tidy car mate, good buy
lol it will be tidy, ya can't see all the dents in the pics, importantly tho no rot whatsoever!
bit like my blue gti cabby that aint got any rot either and only 69k on the clock! this one has done a few more than that as per previous post!
borednow said
Good work so far bruv
hehehehe…. I'm saving all the dirty hard work for when you get home
apparently it's black
and in a bit better shape than I was expecting (after a little cleaning) the carpet was minging though I jetwashed it fro about two hours and the water coming off it was brown, after it had dried there was still sand etc coming out from the pile but it's soooo much better than it was! I recon i'll give it one last hoover before I put it back in, also while it's all out I spose I'd better run the cables for the stereo instal
recon after much deliberation my power steering set up may not be a dealer fit option…
that shocking piece of butchery can't have been done by a pro!
front bumper off and the front wings look to be in not bad shape (you can see the position of the pas line which some bright spark thought it would be acceptable to pass across the outside of the front panel recon i'll be sorting that right out, that is if the pas all works o.k. after the new belt is fitted, if not it'll get a manual rack!
1.8T CABBY
1.8T CABBY
jayc said
The PAS pipe on the outside is likely to act as a cooler for the fluid.
really???
engine bay area looking a little better with all the black paint removed, just need it steamed off now which I hoped to do today but it's raining again
also cleaned off under the front arch areas
would like to get the damper toobs off as well and get those painted up as they look kaka!
