Which mounts for O2A Gearbox?
(In Topic #183809)
I'm changing my gearbox over from O20 to O2A and need a bit of help with which mounts to buy.
I'm using the Epytec mount here: with (edit) 64mm diameter. Does anyone have the rubber mount part number please? Is it available from VW?
Have they sent me too many rear mounts? I'm assuming there should only have been one in the box?
Also, do I need a new mount for the rear or will the existing O20 rear mount fit? (It is nearly new)
One final question does anyone have the part number for the bolts and nuts that attach the rear mount to the gearbox?
Thanks in advance,
Last edit: by Mike 16vG60
The ring in the gearbox mount calipers at exactly 64.00mm so I think I want part no 171199214H ?
£20 delivered for a febi one from vwspares, so not too bad
Febi 07578 Engine Mount | AVS Car Parts
