Series 1 Another G40 build
Full set of chrome strips and clips
Fuel cap decal
Boot side panels
Grill clips
New scuttle
Heater hose grommet
Door lock pin surrounds
Number plate lights
And so it begins
-z
i pressed the little red button
Well todays efforts included washing all paint dust out and off of just about everything and treating all the plastics i have
Started by completely emptying the car and boxing up engine / interior / exterior parts
General dust and crud / leaves from heater blower
After a hoover / wash / polish
Rough fitted the rubbers to get them back into shape
Scrubbed the lights and plate and fitted
Cleaned the engine bay and front panel
Fitted the front end up
Tended to the switch looms with tesa tape
Sat the dash in place amd fitted all the parts i had so i can see what i need
Quick question but was this the one with the g40 engine? You using that engine or not?
1983 mk1 golf driver, small block 4 speed goodness.
Mattkirk - yes has G40 engine, i've had a lot of g40's in the past and done a few g40 conversions too. I've done a lot more 1.8t conversions but wanted something fun and light with small cc. Did have a fair few 20v parts set aside while i was looking for a shell but luckily found ths beaut
I took the dash section home to strip it out and give it a better clean as it's a little delicate
Detergent wipes to remove grime and paint dust
Stripped, cleaned, brushed and treated 3 times
Dash looks good
Andy have redone my loom too recently with Tesa and you go through more than you might imagine for info.
when you get the tesa tape make sure you get the fabric / cloth tape as they do a nylon version that is not so good
i need to work out which order to get parts on my 'need' list so i can make best use of my time and £££
the first revision list has now grown massively to;
bumpers
carpets
headliner
door cards
servo / pedal box
full exhaust
4 branch manifold
seat belts + clips
fuel pump
fuel lines
boost pipes
clutch cable
accelerator cable
coilovers
wheels
front small block engine mount
intercooler
radiator + hoses
indicators
drivers door lock pin rod
internal bootlid cover
door handle screws
non gti door pulls
battery box / battery
e30 battery leads
polo cam cover
polo ht lead guide
slimline fan
handbrake handle
air intake and filter
i think i'll attack the engine loom and reroute some of the car loom as that will be time consuming and free while i save some more pennies
Matt
Well not a lot happening apart from the postman arriving
Todays deliveries consist of:
Stainless bonnet hinge bolts
Stainless wing bolts
Rear cluster bulb holders
Seat guide
Door handle screws
12mm foam tape
6mm foam tape
Trim clips
Washer jet
Tesa loom tape
Early glovebox lid
Also been to see a scrapper mk1 i'm looking to poach some parts off, fingers crossed
1983 Pirelli Edition - http://vwgolfmk1.org.uk/forum/index.php?page=topicview&type=view&id=165792
