Slippy8v's Syncro now with MOT
right side before and left after the clean
this is what came out
Smudger
Was off over xmas and new year so had the time to get stuck in,back to work tomorrow so things will slow down again,roll on the bright nights.
Sticker Pig
Thinking of a fold down seat I knew that a shower seat would do the same job,so a quick search of EBay I picked up one for £20 + postage,so if your looking for a drop down seat get a shower seat.
I wanted to fit the seat on the bulkhead behind the front seats but the panel is at an angle half way down where i wanted to fit the seat so had to fit some type of spacer to keep the seat at 90 degree's to the bulk head once it was fitted,so i used a cork sanding block as a test piece which was ideal,just needed to cut 2 bits of for each side. The bulkhead was not likely to take the weight of some one sitting on the seat so made up a backing panel from a bit of alloy tread plate i had,made it so it runs up the back of the bulk head as i want to fit a padded back panel for the seat.Got it all bolted up and tried it out,no problems taking my 15 stone lol.The seat frame will be painted and a seat pad and back pad fitted later.
Sticker Pig
