82 mars red GTI
The little GTI, 82 mars red mk1
sp8y said
Cheers Andy , this should be getting dipped when yours goes to the body shop!
Nice, not long now then!!
BUT the bad news is on closer inspection the 'repaired' boot floor and rear panel aren't actually that good, I could have done better! The boot floor has warped and now looks a total mess and the new rear panel is now dented and also looks a bit of a mess. To top it off the rear of the chassis legs that needed repairing (one of which I supplied a new one for) hasn't even been touched!! In the photo I put up a few weeks back it doesn't look look bad other than it dips down in the middle which I wasn't happy with. I asked for this to be put right but instead it ended up worse. Think I may wait a bit longer on the dipping and get this all sorted first.
cf_emoticons__BangHead:cf_emoticons__BangHead:cf_emoticon
s__BangHead:cf_emoticons__BangHead:cf_emoticons__BangHead:
cf_emoticons__BangHead:cf_emoticons__BangHead:cf_emoticons_
_BangHead:cf_emoticons__BangHead:.
One thing they did do right though was the clutch repair.
So anyhow I've finished the top of the scuttle and tried the rain tray with seal on to check it all fits right, which it does so thats another thing done.
Welded up the unneeded hole in the new arch tub I had fitted and cut a hole for the fuel pipes to run through and made a new fuel pump bracket which will be fitted shortly.
Picked up some new stuff from MIVW, rear glass seal, rear side window seals, door 1/4 glass seals and a pair of new door striker pins (since the bodyshop lost one of mine + a wheel nut )
Some progress pics too-
Clutch repair
New fuel pump bracket that I made-
Work to new arch tub-
Scuttle repair-
Keep up the good work!
Hairyarse- I bought it from someone on here a ages ago, I think it is from heritage though.
I'd like to say I fitted it but the body shop did it. They did say though that the bit where it meets the raised section of the floor (the bit that the bumper bolts to) that it was a different shape from the original one. Also I didn't have the full thing put in so the back bit that goes to the rear panel is the original one (was a different shape and had the washer bottle holder on it) as I wanted it too look original I wanted this keeping looking like it was. Sorry I'm of no help. .
Got my head back from the skim, can't wait to get it back together and on the block.
Cheers anyway
I discovered that when the 'body shop' put the drives sill on they didn't bother repairing any of the rusty inner sill, so I've fix that now, managed to repair it without taking the outer sill off. While I was fixing the inner sill I fitted the fuel pump bracket too. Since then I've got the rotbox booked in at RetroPower for the 12th of April, which was the soonest they had. Means theres no way of it being done for Worthersee or the AGM but would rather wait longer for it to be right. I went for a look around at RetroPower a few months ago and looks miles better than the other place, So hopefully they'll be able to put it right.
Got the Head back from its skim and have rebuilt it with new springs, valve stem oil seals, new injector seats and new exhort manifold studs and nuts. The heads now been fitted to the block and I'm slowly working through all the bits to get it all the engine back together again.
Bought some mk4 rear calipers, mk2 golf 16v front caliper, Supersprint 4 branch and a Bonrath power rohr for it.
Most of the bit I was going to have powder coated I've decided to paint with POR15 as I've got a spare full tin. Was going to seam weld the wishbones but then discovered the previous owner had done for me .
Modified my inlet manifold to allow the Audi throttle body to open fully.
And lastly Got hold of a good boot floor to sort mine out.
It will do smudger I got it from Simon, saw your mk1 there too, very nice .
sp8y said
Thanks Andy!
thought it was from Simons. Were you there chatting all day? He'd chat the hind legs off a donkey that man
That's a good shell you've got there mate.
Smudger
sp8y said
No, only a for a couple of hours.
You got off lightly
will you be using all of the quaters?sp8y said
i could use a little cut off that save wasting another.
i need the lower corner section of the driver side window opening closest to the drivers side door.
Regards Volkswarren
volkswarren- I'm not sure as of yet if I'll be needing them or not, so I can't say just yet, if I dont I'll let you know. Sent you a pt too!
