Wilwood Pedal Box
(In Topic #165180)
I want to get rid of the Seat clutch cable setup which I currently have on my 02a CBA gearbox and convert to hydraulic. I haven't got a clue where to start with this so any tips would be appreciated.
Also will I need to keep the Servo I currently have or ditch it altogether?
Help appreciated
Smudger
abfmk1 said
Do you plan to change the m/ cylinders for ones with remote fluid containers, looks like it would be tricky topping those up under the dash.
Didn't realise they were reservoirs on the end mate tbh till I spoke to JonP on the phone.
Is there a way I could run to remote reservoirs say in the scuttle tray??
Website Manager
lhasadreams said
That is going to be an absolute nightmare to fit !!
Those reservoirs are part of the cylinders, so you are stuck with them :-(
Was it designed for the Mk1 ?
How you going to mount the accelerator pedal ?
I'm getting that impression mate as I go on with the research but got it for decent money
Still as the research stage but I think it is a generic one
I love a challenge me
Modify the body mount for the accelerator pedal and mount that to the pedal box? Or fab up a pin to accept the pedal off the box?
Brad. said
Couple of ideas here, instead of messing with remote resovoir's, take the caps off, get a small bsp nipple and ago the lids. Then run a seperate nylon hose to each nipple and secure at high level??
Sounds good to me Brad me old mucker, get yourself up to York
Hmm. v.nice, I'll be keeping any eye on your progress of this.
</winter build idea>
Il be removing my accelerator pedal soon so il have a look at the pin and see if I can make you so et I g to suit that could bolt or weld onto the wilwood box
