Mk1 Gti soon to be dumping
Mk1 project slow
I bought this techniclutch kit on eBay as I thought it was a good buy. Then my mate started reading bad reveiw after bad reveiw off his phone.
Anyone know anything about them or anybody using them???
Iv not paid it yet but got it for £160!!
Any input/ suggestions would be massively appreciated I'm looking to keep the price down and don't need anything special but its got to be decent.
Thinking going oem again as had probs with fancy flys before
Really need these parts now so I can get on
Last edit: by Dubbuds
Design Manager
Dubbuds said
http://bit.ly/17OsK1B
I paid under £250 for my OEM G60 flywheel which I had lightened and balanced properly by hotgolf on club gti, a Sachs clutch kit from euro carparts on 25% discount and the bolts etc needed for the friction plate. Didn't cost the earth but I did it properly, it feels exactly like a standard 1.8T and revs much quicker. Do it properly mate, speak to hotgolf, he will sort it out for you. I bought a used G60 flywheel off eBay with the part number hotgolf gave me, and he exchanged it for me for one he had lightened already. Took 3 days to turn it around.
Don't buy cheap on vital components mate, especially high speed rotating masses lol
I've also read a lot of awful reviews about the tekniclutch kit.
2018 Up! GTi 1.0 TSI
2015 Mk7 Golf R 2.0 TSI 4motion DSG
2011 Caddy Maxi Kombi 1.6 TDi
1982 Mk1 Golf GTi 3 Door 1.8t - Build Thread
Cheers for the heads up 90
Im actually starting to forget iv got this..
Picked up a oem flywheel
and a luk vr6 clutch.
also started to get the gearbox ready for putting it in.
How it was
Started to clean it up
Washing it down
Gave it a lick of paint and started to replace the bolts
Not the clearest of pics.
I need to get a release fork and spring now, then get my mounts powder coated and the rubbers inserted. All this week hopefully as this wkend is booked for the Mk1
Got the lower sill trim on and trial fitted the bbs while they were off the mk2.
Before
After
Bbs at far to wide to be practical unless I raise it right up.
This is the spacer at the rear which I'm going to remove
Does anyone know where I can get a pipe that fits between the filler neck and tank?
Passenger side still to do lol
Got the door alligned perfectly now thou ready for the black stripe to go on.
Stuck the back lights on to
Pretty chuffed with the trim and stickers managed to get it all straight
Couple shots
Couldn't get clear shots as the sun was so bright.
Also got the sunroof out and the stickaflex* ready for bonding the roof on.
Also this is the spare boxed one. Will be selling these now I think.
Totally copying the ones on the right when mk1s ready
Window runner bars to be powdercoated before I can get them in to.
Back tucked up waiting for next time
The pictures have uploaded blurry which is a shame.
It was quite a bit of work drilling the body for the lower trim. Wasnt a nice job to be sticking a drill into the side of car but it had to be done.
Next side will be much quicker.
Also got the tailgate sticker to go on and loads of other oem like stickers from ebay. Looking forward to that just need to find the right locations for them
i had great trouble finding the correct sized hose when i replaced my fuel filler, size is 40mm inside diameter x 165mm long if i can remember correctly
I could only ever find 38mm which i couldn't get on or 42mm which is what i used
but i'm pretty sure vwheritage now sell the correct hose, probably a bit pricy though, i should really replace mine with the correct one
'83 formel e
there you go but nearly 20 quid for a short piece of hose
'83 formel e
ned_h said
http://www.vwheritage.com/vw_spares_Fuel-Filler-Neck-to-Tank-Hose-MK1-Golf-N90119601_act_shop.product_pID_66723322_lang_EN_country_ES.htm
Cheers for the info and the link mate. Il get on it
Dubbuds said
Yeah mate il sell you it I'm not going to use it.
Hi Mate,
Are you agreeable to my suggestion of a tenner for the badge, I can Paypal you if you are. ?
Where are you based mate ?
David
1991 Golf GTi Rivage - Show Car 1983 Golf driver - Restoration Project
Had the mounts powder coated
Got some more stainless nuts and bolts
Got some nice new vag boxes today but forgot to take a pic of it all with being eager to get it all on. Plus the old water pump went back in the new box.
Timing belt
Oil filter, sump bolt and washer
Also a new water pump and 16v manual tensioner.
All fitted. Got the mount insert pressed in today to. That was tuff going
Going to put a stud in the block for the tensioner sometime to.
Got the flywheel and clutch on with the box so I could time up the new belt.
Fitted a new release fork and spring to. Hopefully more pics tomorrow and clearer ones if I can find the part I need
Cracked on with it and was a bit of a wrestle with no hoist.. Just a big jack and a strap.
10p part
Had the back gearbox mount on the wrong side at first
Old school engine entry
Good day at last
