Not Starting when hot
catch the drained fuel and store it in a sealed container, its great for cleaning parts!
Chairman
Is the valve the 'check valve for fuel pump' at the top centre in the diagram??
as i say, you may find if the end nut for the fuel line is siezed that the non-return valve comes undone when you try to remove the fuel line. in this case you can just remove the wires and end pipe from the pump and spin it round till the valve is out, then get a socket on the back of the valve to hold it while you free off the end nut
Chairman
I think I'll have to take a trip the A5OPY's man cave to investigate!!
It was a bit of pig fitting taking the cage off and refitting
The bosch pump come with the non return valve
GTI Campaign Helios Blue, Going back Standard
GTI Campaign Schwartz Black shouldn't have sold
GTI Mk7 Performance pack Daily drive
Polo 1.4sel Sunset Orange The Wife's
Triumph Tiger
Triumph Tiger
rubjonny said
sorted
Cheers Rubjonny as always your there to help cheers
Triumph Tiger
Triumph Tiger
Honorary Member
Seen rubjonny's post about the valve and accumulator (which I will be changing). Just to confirm if there is a lifespan for the fuel pump (worth changing at the same time ?)
Plus I can smell fuel when the exterior temp is hot like last sunday
Last edit: by campaignjerry
<a href="Pictures by campaignjerry - Photobucket"><img src="http://i286.photobucket.com/albums/ll103/campaignjerry/Reworked-LogoRight.jpg" border="0" alt="Photobucket"></a>
