Right hand cornering and cutting out
(In Topic #154300)
Chairman
Good pick up, tick over, warm up is fine but when I reach a right hand corner 'at speed' such as a roundabout the car judders and misfires. This happens when I have about 1/4of a tank or less, not when the tank is full. As soon as its on the level straight again its back to normal with good running. If I take it slowly round the roundabout there isn't a problem.
Is there a fuel pick-up pipe in the tank or similar that may have come off because I thinking that it may be fuel starvation as the petrol swirls to the left away from the pick-up. (assuming the pick-up is on the right!). Any clues would be gratefully received.
Thanks, Dan
Website Manager
Chairman
lhasadreams said
Does sound like fuel starvation though. What's the system pressure like ?
With my limited knowledge it feels like the engine is 'gulping in air' and guddering for a couple of seconds until I come off the bend/ roundabout then it back to normal.
Do you think that it could be related to the non sarting issues in Germany? I've not had it pressure tested, I'm waiting for my invite!!!
Chairman
Early-1800 said
My GTI has always done this when below 1/4 full and going around large roundabouts with some gusto, like at motorway junctions. Not a problem when you are aware of what happens when low on juice.
Have you ever explored the issue? It's very off putting for passengers and it gives them ammunition to 'tut-tut' at older cars!!!
Chairman
It makes me jump every time it happens and I think that Im going to break down!! Keeping a full tank should help.
Catches me out at the end of the M65 and the roundabout at the end of my village.
the gti fuel tank should have an internal swirl pot that stops this from happening, take a look inside to check that its there and the rubber flaps havent degraded. cheaper pattern tanks do not have this swirl pot and hence fuel starvation occurs.
i had a floppy top 16v with the old mk1 gti fuel tank setup, and never had any issues with starvation when cornering. you need to fix this asap, as if the fuel pump runs dry it can become damaged as it needs the fuel to lubricate the internals
Member 125 - 2005
As far as I know its still the original tank and don't remember any rubber flaps inside?
This problem has come up a few times in the past so its really is a design 'feature' that you only get depending on speed, road, fuel level or some of us have a bits missing from our tanks?
Chairman
Can the inside of the tank be viewed easily to check on the rubber flaps??? What is the solution? New tank??
Member 125 - 2005
as for the tank:
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=how-to_2%2Ffuel-tank-cleaning_3
if your swirl pot is gone you might want to think about fitting the post 84 cab/rocco or g40 shape polo lifter pump and fuel reservoir, this will solve your problems. the main issue with that though is finding space for the reservoir as it goes where the accumulator is now!
Chairman
I don't have a compressor or such like to hoover out the debris but I do have a powerful vacuum which would do. Im concerned about the EXPLODING comment though!! If I got a length of thin-ish pipe, taped it to the vacuum and used the pipe to suck up the debris would that work? The vapour would be able to escape from the tank through the opening and any sucked up would escape from the vacuum.
Or… Would the vapour explode in the vacuum (is that what Chudd meant?)
The old magnet trick may work on a bendable length of pipe.
I've never cleaned my filter so it'll be a job worth doing I suppose.
What happens to the swirl pot? You say 'if its gone'???
what i would suggest if its full of filings is scoop out as much as you can with the magnet, then drop it in and drive the car for a few days. remove, clean, drop in, rince repeat untill no more metal comes out. of course you want to make sure the source of the metal is identified, i.e. filler neck or ropey tank.
then if there is any crud left either remove tank and rinse it to get rid of as much as possible or use a rag/sponge on a stick to tery to get the worst of it out.
with the swirl pot its a case of check it over, if the rubber flaps inside have gone then i dont think there is an easy way to repair it? if you can dismantle it you may be able to use whats left of the flaps as a template to make new ones, but trouble is you want to make sure that rubber is fuel safe otherwise it'll dissolve away and cause you more problems!
as i say, if its gone you might find its easier to bin it off and switch to later setup, if you can find room for the reservoir. then you would block off the old outlet on the bottom and run the pump to reservoir instead.
tank nipple for the engine fuel return is blocked off too, this pipe is fed to reservoir instead. then theres a feed and return to the level sender itself
Chairman
Magnet, stick/ string and a rag firstly. Get most out.
Drive around so more sticks to. Repeat as necessary.
Find cause!!
The rest… Well, that'll be a new tank I think
I fully drained my tank when the car was in bits being bare metal restored. With that done I shook the hell out of it and did fetch a bit of rubbish out but reading the fuel tank cleaning I didn't realise there was a filter in there. Ill give that a clean today.
Failing that though Dano i'd just put it down to the character of the car
I have had this issue on jct 36 and 37 M1 so I'll have to try your favourite roundabout next
Why did I start this
