Series 1 Fuse Board - ABF Conversion
(In Topic #147860)
All thoughts are gratefully appreciated!
the alternative is splice all the old ceramic fusebox wiring to the mk3 fusebox, using wires from the mk3 to repair any crispy bits on the mk1 loom. but note the engine loom will still need modification because the fusebox sits on the opposite side of the car.
you could relocate the fusebox to the driver side, then drill new holes in the bulkhead. then the mk3 loom will fit much better, you#'ll just have to splice mk1 plug ends on to suit the mk1 clocks, lights etc.
but easiest solution is get a complete mk1 later fusebox loom, tintop will be direct fit, cabrio is close but it has different light plugs and no rear wiper. you could splice the old ends on to suit, just match wire colours. if you dont want rear wiper/washer then that can be left out. dash and lighting loom is same tintop and cab, any later mk1 engine loom will do you just need the bare minimum from it for use in the conversion, wiper loom some sensor wires etc, then you splice this to the abf loom once stripped down.
