The scary G60 conversion
(In Topic #144622)
So to date i have purchased the following:
PG engine with 90k miles
Refurbed unused Jabba Stage 2 Charger (Going to run standard pulley to start then get new chip etc for full stage 2)
Full gasket kit including head gasket
Cambelts/tensioners etc.
Full loom with corrado fuse box
Standard corrado g60 ecu
Custom engine mount for mk1 conversion
Slim line custom tensioner
I am looking at buying a TD5 intercooler as it appears they are the easiest for this conversion
In the last year and 100 miles the car went through a full rebuild including?
1.8 16v full brake conversion all round with cylinders including a variable brake bias valve in car
Braided brake lines
Uprated fuel pump
New fuel lines
Coilovers
Everything polybushed (engine mounts, steering rack etc)
Uprated front and rear anti roll bars
Resprayed engine bay and exterior
New stainless steel exhaust system
Battery relocated to boot
Washer bottle relocated to boot
I will add photos as the build commences and carries on, i have changed engines before but never a full wiring integration like this so i am expecting many bashed knuckles and screams over the next few weeks LOL and if your in the watford area feel free to pop round if your interested.
Current MK1 rebuild elapsed time - 15 years and counting…
Is it normal to clean and paint bits of your car that will never be seen?
Not-so-new addition - 1996 MK1 Citi Golf (off the road for 4 years… and counting)
I finished off with mk3 vr6 fuse box and untouched mk2 g60 lhd wiring loom
1979 mk1 Golf Gti (Dan)
2010 T5 Karmann Colorado
2012 mk6 Golf Tdi convertible
2018 VW Amarok V6
2018 VW Amarok V6
As to the wiring i was going to use the full corrado loom and fuse box if possible as its matched to the engine all though its located on the right hand side of a corrado normally and obviously mk1's are on the left but i am hoping that with a bit of magic and extending if necessary it will all work, Or worst case i move it to the right in my mk1 as theres room under the dash
lazey_boy said
I am actually going for the stock 1.8 8v g60 as i want it to be reliable at stage 2 tune, in a mk1 you dont need much more mine is fully stripped with a half cage and one ultra light seat so with around 210bhp and weight of circa 730kg gives me 288bhp/ tonne or put another way enough to scare myself :-D.
Ah, of course. You did say PG engine. I got too excited. Surely the 16v one is the really scary conversion
This is a picture of my current setup, some of my friends think i'm crazy but its the G60 sound i want lol probably won't be much quicker eithor but c'est la vie
dub-step said
you had a good lil buy on that car gonna paint the engine bay while its out?? looks a bit random blue
+1 , my biggest pet hate , half a respray !!
Website Manager
On day, many years from now I will have to decide on either 16v g60 or carb…
I love whats been done but again its also not a G Ladder which i believe is the only progressive supercharger which also accounts for the inherent wear in the design lol, I guess the heart wants what the heart wants and i promised myself one years ago when i bought my first mk1 and went to santapod, and some guy was running mid 10's in a white mk1 G60 and the sound blew everything else away on the track :-D it was love on first sight lol
Website Manager
The best guys at GTI International in a Mk1 Golf achieved 9.9s quarter and 2.6s to 60 - this requires 4 wheel drive and 700bhp :-) - It was built and geared for sprinting.
Not sure what you mean by "progressive supercharger" - Twin screw chargers like the Lysholm are more efficient and effective across the rev range. G60 ones are not as efficient and do have wear issues if not looked after properly - but then that is true for everything.
What the G60 does do is up the torque level across the rev range so that makes for a really nice drive out on the open road - where most of the enjoyment and driving will be done.
My engine you see above was once an 8V G60, then a 16V G60 and now a 16V Lysholm.
Still want to see pics as you progress though !!
As to what i meant by progressive its a scroll type rather than a sliding vane or screw style charger, and is in theory the optimum operation for a supercharger (This is taking acoount of sound levels crerated as you say a screw style produces the most boost but is not efficient in other areas) except for the wear issues they discovered as the tolerances have to be so fine for its operation, its a bit like concorde amazing but flawed lol
Yours looks incredible though whats it producing i am guessing 260+ and how have you found reliabilty on it as i did nearly buy a brahn supercharger instead
Website Manager
It is a myth that then G60 unit is unreliable - it just needs to be fed with clean oil, i.e. regular oil changes and a clean effective air filter - the guys at JabbaSport see them with 90K on them and no running issues at all.
This one !!
9.9sec Golf
Mine produces 230bhp and 192lbft of torque - down on what it should be as I am losing boost (it sees 10psi, should be nearer 17).
I am pretty sure that the clearance for the pistons for the over bore is too much (it uses oil) and I am losing boost past them.
Oh well the joys of building and running modified cars !!
Planning on a winter rebuild…
It is still a hoot to drive though :-)
Surely you would hear some piston slap though if it was a problem with the bore size, i know this may be a dumb question but have you put a pressure reader on the pipework just before the manifold, my friend had a similar problem turned out to be a tiny hole in his intercooler of all things where a weld wasn't done quite right
I have a freshly built by Jabba Stage 2 charger so am hopeful i shouldn't see too many issues with it :-)
As to the modified cars comment i so agree, the pulsar i mentioned ate the gearbox twice, and constantly had fueling issues not fun at all. Main reason why i am going for the full engine transplant at least its all standard :-)
Website Manager
I have pressure tested it and could not find any leaks :-(
It uses about 1 litre of oil every 200 miles, no smoke though and no leaks. The exhaust is sooty and you can smell the oil has been burnt - a bit like a two stroke.
I have done a cylinder leak down test and all four are showing 20% which is a little on the high side.
The pistons do not slap at all.
The breather is vented to air and you can see vapour coming out of it and it generates quite a lot of gunk in the breather pipes.
The bores were taken out to 83mm with a 0.006" clearance as per the Ross data sheet - which is quite a lot of clearance…
I hope it gets sorted soon as its a work of art that youve created :-D
