Oil light and buzzer help plz
(In Topic #144476)
Dave
Chunktheskunk said
They are the correct way round. someone has advised earthing the yellow wire. should i do this?
Earth the blue wire :wink: Thats the one that operates above 2000rpm.
If not that then its the clocks. Theres a little guide in the Electrical FAQ how to diagnose the problem
But i still get the buzzer when over 2000rpm, i take it the next course of action would be to check the oil pressure with a gauge? Although with new sensors this shouldn't be needed.
Or/as well check valve clearances? I am a little confused by it, little thing was working fine, topped up the oil cause it was a little low, now leaving me with headaches from the buzzer.
Does the sensor go nuts if you put in too much oil …. I dont think that i have, the dipstick (in the engine not me) reads at the top of the two dimples on the stick.
Everyone loves pictures, my little 1.1 formel e block post new sensors … yellow wire to blue sensor, low pressure switch, green (but black/blue-ish post little block, which has always been there) to high pressure
If the sensors go on the other way round, the the oil light flashes away to its hearts consent … so working switches there i think.
Any help here chaps, thanks.
did you double check the ratings on the old sensors that you took out, as im not sure if the small block ones are slightly different ratings
Just waiting on an email back from a VW garage re pressure switches. fingers crossed this cures it. Before bugjam.
