Horn gremlins
(In Topic #142683)
Horn gremlins
I then took the horn off and connected it direct to the battery, horn worked
I re connected the horn back up, obviously I knew that it wasnt going to work, and it didnt. So, I connected up the black/yellow ( I believe is live) wire to the horn and ran a wire from the batt earth to the horn earth and it was constantly belting out a beep, as if the steering wheel horn was being held.
Is the horn switch connected to earth so when its pressed it makes an earth?
Because I thought it was switched live?
i'm confused to what it could be. It used to work fine, and I havnt touched the steering wheel.
Help?
Twitter Manager
VW wire the horn totally differently to the rest of the world. +12v is run to the horn permanently (or at least when ign on) and the switch at the steering wheel earths to -ve.
There are relays involved (on GTIs at least) and the horns draw a lot of juice, any slightly duff connections and they won't work. I'd start be removing the horn/s and testing direct to a battery, even if this works doesn't mean that the horn will work when back under the car. Another trick is to just have one horn on the GL/GTI setup as both seem to overload the system.
Thanks for helping boys
Life Member
Earth on steering column
Spring connection under the steering wheel itself
Relays and fuses
FAQ Section
May help
i also have a problem with my horn..
i have read this topic and will check everything i can..
wanted more details on where this earth is on the steering rack please?
my horn does work but very low, not loud at all (maybe one 1 of the 2 are working :dontknow
would mine be the same problems as mentioned or would someone know whats wrong here?
Thanks!
Twitter Manager
The Mk1 Golf Owners Club
would it be possible to sort it out from underneath the car if it was on a ramp?
i couldnt tell exactly where that is but seems like its the left side from looking into the bay..
