S1 1979 inari silver PD TDI
(In Topic #142198)
after a good road trip down to the south coast and back, she was parked on the drive, and left untouched for a couple of months until i decided exactly what i wanted to do to her!
i haven't taken any progress pictures along the way, been getting too over excited and just working hard on her lol, but will take a picture of how she stands now as soon as possible! so far i have totally stripped the interior, seats, trim, dash, wiring, the lot, removed the underseal, taken the sunroof out as that will be welded up, replaced the front lower panel, rear lower panel, both rear arches, and repaired a section on the spare wheel well as they had succumbed to rust bunnies!
over the space of this weekend i have now removed the engine, gearbox, all the running gear, lower arms, exhaust and now only have the rear beam and tank to remove, then she is ready to be put on her side and to have all the underseal on the bottom removed and renewed!
when i made up my mind what engine i wanted, i got searching on ebay, and managed to find a t-boned bora very close to home. this was snapped up rather sharpish, and is in the process of being stripped now. this is the donor car:
it's a 1.9 tdi pd115, with 160k on the clock, full service history, and before the accident had a brand new hydraulic clutch system, luk replacement clutch and re-con gearbox.
i will try and keep on top now i have managed to get this up on here, and take as many pictures along the way as i can. all thoughts and comments welcome, and as and when bits are done you will see the direction i am taking the car in!
azza
subscribed :wink:
I miss my old one.
It's great if you got them engineering skills too.
keep up the good work.
Chortle
Iv got to take them camera outside
Today I have taken off the rear beam, fuel and brake lines.
What have people done with there bias valve spring things lol
By the way I don't have any engineering skills just taking my time and see how things go and if I need anything made I will do my best to make them first.
Not sure how the driveshaft set up is gonna go down but we will see
I have taken all the running gear to the shed for a full strip down and removed all rubbers and given them a paint of satin black with a quick blast coat of lacquer to seal them. Im going to drop the tank tomorrow and steering rack and it should be ready for a place on her side for a few days
Azza
bye bye sealant:
no rot round the screen very happy with this :
big pile of panels:
painted bits:
and done :
Had a very sunny Sunday so got loads of work done
Mr andy Kirby came over today (you may know his amazing mk2?) he got to work stripping more underseal
While I welded up a small little repair in the passenger footwell.
Then we undersealed all of the inside of the car then layied soundproofing over the top to make it nice and quiet.
We also had time to lay a few coats of soundproofing on the insides of all four doors.
Got cracking on my dads garage the other day if was full of rubbish and plasterboard (because they have gone on holiday) I cleaned it out and screwed up the plasterboard and made my perfect work station for the mk1 got a couple of buddy's over to give me a lift with it. We just stuck sone 2x2 in the chassi legs and just lifted (will show you all the pics) so wind rain or shine I can work on her. Maybe until my dad comes home and kills me?
I have only had it in a few days and so far I have stripped all the paint off the bay and half the shell. Once when I have taken off all the paint I will filler up all the little dents then shoot it in some primer then I will either turn it over and do the underneeth or get the bora home and start mocking up all the pd parts?
Pics to follow
i have now welded up all holes in the engine bay and no paint left on the car what so ever hope i remember the inari silver paint coad lol. also took off my gearbox mount and waiting for the pd lump and 6 speed. i will have to re weld it back in once i have the engine and gearbox in (roughly)to support the weight as shes a heavy box. also i will chassi notch once when i have sorted out driveshafts and gearbox cups. got a fealing mk4 golf 20v non turbo 100mm cups will fit on my box?!? but not to sure. any info on this would help massively.
pics to come
azza
The amount of people that say that.
Now it's in the garage I don't have any excuses.
Just get on with it I suppose.
Underneeth next! Then bora tank sunroof blank then the pd
good day today! well half day after work!
rolled her on her side and took off all the underseal grease and other crap now just left with a car with no paint or underseal on now and is very light
Im going to order some por15 and wax oil to do the lot in. fit the bora/mk1 tank with filler neck then roll her back over again. Any other thoughts on what i should do now while shes like this would help massively
G60
Well come over and take a look then!
Welded up the passenger sill and joint plate from the spare wheel well to the rear panel.
Also seam sealed all the underneeth waiting for a bottom and top coat of por15 and wax oil might also Shutz the sills?
