1.3 keeps cutting out when ticking over
(In Topic #138124)
thanks
sam
if it's a cold-start problem, then you need more choke - simples
if it's a hot-running problem, then you may have an air leak - check the joints on your carb to the airbox, and also the joints in your inlet manifold.
does it just cut out as if you turn the key, or is it like it's slowly stalling?
there's still a number of issues it could be - try that first.
P.S. try pulling the choke on whilst it's hot, see if that sorts it… could prove an air leak.
1983 Golf 1.3 Driver:
