FLASHING RED TEMP LIGHT
(In Topic #136032)
unplug the sensor and its like your tank is empty, the pins need to be closed circuit to switch off the light. the way it works is the probes on the level sensor make a circuit when submerged in water see
one common problem is the tips get all dirty, sometimes taking out the sensor to cleaning them up till shiny will solve the problem. other issue is a duff sender can allow water to seep up the level sensor wires and corrode the wire/relay pins, plus water damage from leaky fusebox onto the level relay.
as i say, for an easy life you can just yank out the control relay and that'll disable the level sensing. the dash will still work as will the overheat warning light (same light as level warning)
