top mounts
(In Topic #134114)
top mounts
can someone tell my why they have done this already and if this is what should happen or not. i am running coilies < does this make a difference?
i am having the same problem.. which is the biggest problem for me right now.. you can read my post.. (suspension mounts - koni)
i have changed bran new mounts with bran new shocks and this keeps happening.
ive had enough and now taking my car to a specialist booked in end of the month with The Phirm..
http://cgi.ebay.co.uk/VW-Golf-Mk1-Suspension-Top-Mounts-Adjustable-CMB0223-/320668335862?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4aa9527ef6#ht_1977wt_654
There crap. You need FEBI ones mate, altho they are probably hard to get hold of these days….
im actually glad you mention these, i have seen these mounts in pics of other mk1's..
im going to the phirm end of the month and he says he can sort em out, as they are specialists..
what brand are these?
are they actually £130 each ? 8O
can i not get these cheaper elsewhere?
how long will these last for?
do you know of the problem we are having, and will these mounts to the trick? and why?
at the phirm it will cost me around £132 for 2 hours labour to dis assemble and re assemble my front suspension..
but if your saying these will work, then id rather not take my car to the phirm and spend that money on the mount.. 2 hours labour instead i could get 1 mount for that price.. i keep spending which adding up is getting costly.. thats why i thought to get it to a specialist and get it sorted.. i have spent alot in trying to rectify this with my mechanic but not getting any joy… the same mechanic has done this for me in the past with the same parts and they were fine but now i dont know why this is happening..
appreciate your help
thanks!
same as we did prevoiusly around 1.5years ago when they were fine..
i dont really wanna be spending £260 just on mounts :cry:
i just seen em for £50 each which is much better than the £130 on ebay prices..
are they the same? http://www.compbrake.co.uk/TOPMOUNTS/TOPMOUNTS_VW.html
never had any problem with them .. although I am on standard suspension
http://www.vwspares.co.uk/g1csuspension.php
Tony
some pics of mine before and after on my rivage thread below
but when did try em last time they were fine.. got em from vwspares..
i dont understand why this is the case when same process with same mechanic in the past worked fine but now its not happening..
i have my car on Koni Dampening Adjustables.. (lowered) with the mounts shown
cost about double the price, but if will work and last to me it will be soo well worth it
abfmk1 you say surely thely bring noise and vibration up.. do you know this?
my car is my daily and drive it daily.. at the mo the way the mounts are shot its horrid to drive as the mounts havin given way.. i cant take the way it is now with bumps etc.. making things in the car make noise..
i do notice on the pic of the solid mounts there are no rubber…
so whats the big difference? :dontknow: :dontknow: :dontknow:
found this site as well but no price info! http://www.motorsportengineering.co.uk/fixed%20top%20mounts.htm
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=59610
http://www.bonrath.com/shop/product_info.php/info/p4482_Bonrath-Domlager-VW-Golf-1---Jetta-1---Golf1-Cabrio--.html.
will this them n fix my tracking problem - in the fact that i get it all done square on and then two miles down the road its miles out again -
also i under stand that there is only one side that can be ajusted on the trackign is this correct or if there two ?
RIVAGE69 said
just checked out the mounts ( top mounts CMB0223)
just been on this link - ok im getting fussy now - but the pic spec the one on the left has a different hold positioning - i h=guess that you have to drill the body work ??
it also mentions some are adjustable and some are fixed . whats the difference please??
they are the same type £130 for two or £50 each ie same part number. just check its not £50 plus vat and go for the best deal. i think the 3 hole type is only £5each cheaper. the adjustable ones adjust both caster and camber so you can get the set up just right. you adjust it by turning it round hence why the suspension hole is off centre
also i know what camber is but whats caster?
sorry im still learning
