16v engine in a MK1 by paul-c
Re: 2.0 16v turbo
turbonitis said
it looks great, well done. I am also doing the same but don't know which way to go. don't want to make a wrong choice. if you know so much is there chance i can call you and have a chat? send me a text on 07772255014 and i will call you back, the best time is about 6.30pm i would be very grateful if you can help as i don't know to much about doing my conversion being waiting to long (2 years) with shell fully resprayed, had a 16v empty engine bay HELP
Just post a question if you're unsure of something, loads of people have done the 16V conversion so they'd be able to help you out. Which bit are you stuck on?
paul_c which kind of fuel pump do you use?
Need a part help
James
lipek81 said
We put 9A enigine in mk1 golf with my colleauge, but we have problems with fuel pressure. Fuel system from passat have a two pumps - one in the thank. But pump from passat is to big to put them into the thank from mk1. So we use fuel pump from mk1 GTI, but fuel pressure is to low.
You're using Mk1 GTI pump? Should be fine. Are you using Mk1 GTI tank and Accumulator as well?
1979 S1 MK1 Golf L FOR SALE! http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=101471
1970 VW Beetle 1600 Twin 34 ICT\'s - Betty
1973 Marathon Beetle - The Moll\'s
Matt
