Mk1 golf gti, 2L 16v, R1 Carbs. Nurburgring Nordschleife
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/8image.jpg)
![caddyrage in the usergroup ‘Regional Hosts’ caddyrage in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![caddyrage in the usergroup ‘Local’ caddyrage in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Mk1 golf gti, 2L 16v, OZ turbo's. R1 Carbs
Cant really see the colour as it was dark
![](https://vwgolfmk1.org.uk/uploads/pbextract/1077552/golfgti189.jpg)
Need to sort another top rad hose as the carbs hit the one thats on there now
![](https://vwgolfmk1.org.uk/uploads/pbextract/1077552/golfgti190.jpg)
92 caddy, Now stripped for full rebuild
83 golf gti R1 carbed 16v(soon to have 1.8T)
07 Leon FR TDI daily
Cambridgeshire regional host
![Avatar](https://i763.photobucket.com/albums/xx271/m-chidz/Picture147.jpg)
![Chidz in the usergroup ‘Local’ Chidz in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Cheers.
Chidz said
Loving the work mate. Are the tyres on the OZ Turbo's 185/45 all round? I have just got some Turbo's for mine and want to make them 7.5 and 8.
Cheers.
Cheers mate
Yeah the tyres are 185/45's all round. Nankang ns2's.
Kumho also do that size but i've never found someone that stocks them
Cheers dude.
Cero said
Just read it through from the start, you've put some serious work in there, very well done.
Cheers man. There's more to come
Done some more to the golf today with a helping hand from my mate who has and ABF'd mk1 on ZX9R carbs.
Knocked up a brake servo to inlet vacuum pipe then turned my attention to mounting the carbs.
No way that the Head water flange will work due to the height/drop of the carbs so got on the phone to bogg bros who are going to make 1 on monday and send out same day for tuesday delivery. Now thats service.
Anyway, although the water circuit could'nt be complete, it did'nt stop us from getting other stuff sorted
Cut up some new black silicone hose to join the carbs to the inlet then checked for clearance to the bonnet and rad with the filters on
![](https://vwgolfmk1.org.uk/uploads/pbextract/1077818/golfgti191.jpg)
All looked lovely so then it was a case of making a throttle cable up. Took some time doing this but got there in the end and all works correctly.
Cut and fitted the fuel lines. Infeed being the pipe under number 2 carb
Oiled up the cams before fitting the rocker cover and dizzy with leads.
Few turns of the key to bring the fuel up gave us a problem. She forced fuel out the FPR. Obviously the fuel pump and accumilator are much too high a pressure for what i need. I know others have done it this way so i can only think its because my pump is basically brand new as some of you may know the previous seized on my way back from a cambs meet.
Now going to fit a Facet red top when i find one.
Nevertheless, after the fuel had stopped seeping from the FPR. I turned it over a few times before she fired into life
Was well pleased she fired up and as i was sat in the car, i relied on my mates who said she sounded great. Sweeeeeeeet!
Not long til she's back on the road now
I have most of what I need to do this, until I realised the KR block has had it. I really want to do this some time down the line, so please make sure you post up jet sizings etc when you are happy with how it runs…
My Build Thread
AL_Mk1 said
Very jealous…
Excuse to swap to 2L bottom end then mate
The carbs have aparently already been jetted to 190 by the previous owner who had them on an ABF.
Will be rolling roading after a couple of hundred miles and done an oil change so i'll update with whats what then
Pleased with how quick they got 1 out to me but when i got home, i offered it up to the knackered spare head i have. 1 of the bolt holes was out of line by around 4mm so had to elongate it so it worked. Good job i tested it first.
I also was'nt happy with the internal port in the flange, see pic. Although its only water, i believe this would restrict the flow of it
![](https://vwgolfmk1.org.uk/uploads/pbextract/1078368/IMG_0143.jpg)
I dremelled it out so it'll flow better
![](https://vwgolfmk1.org.uk/uploads/pbextract/1078368/IMG_0144.jpg)
I also collected my new Facet red top pump last night so i now have the parts hopefully to finish the carb set up off
Thankfully i managed to find a guy who would tig it up the way i wanted it on a saturday.
After the F1 quailifying i started work on the car again.
Modified water flange mounted and a suitable top rad hose found amongst my spares fitted
Like a glove!
![](https://vwgolfmk1.org.uk/uploads/pbextract/1079171/IMG_0145.jpg)
Next job was the facet fuel pump
A lot of trial and error was to be had when doing this as i wanted to use the original fuel pump bracket to hold the facet closer to the outfeed of the tank. Again, this was'nt going to work due to lack of room but in the end i used the original accumiltors bracket to mount the facet further back and then just used longer lines.
No pic of this at the mo as i dropped it off the axle stands to see if it would work first.
Battery back on then after a good few turns of the key, we had fire in the hole
http://www.youtube.com/watch?v=m3lTKcxmEbU
![](https://vwgolfmk1.org.uk/uploads/pbextract/1079316/IMG_0148.jpg)
After the F1 today, i fitted the filters and set the gear linkage up before going on a test drive.
My god its responsive
Going to get a few miles under its belt, do an oil change then have it rolling roaded so its spot on :thumbs_up
Need to source a mk1 golf choke cable as she's poo on starting
![Avatar](https://farm6.staticflickr.com/5118/7081033079_b9d6aa250e_q.jpg)
![tomsdubs in the usergroup ‘Local’ tomsdubs in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
tomsdubs said
Did you polish the inlet ports?
I did but round the valve guide area in the ports is rough. The inlet is'nt polished either so there should be plenty turbulance for the fuel/air to mix.
Now booked in at rolling road next wednesday too
Also have an original mk1 golf choke cable to fit
Sounds great.
Have these Carbs been on a car before? What has been changed in the carbs from the set up as they were on the bike for it to start and run so smoothly?
Have the jets been drilled and have the main needles (or tubes or whatever they are called) been spaced up, as I have read you have do do this to get enough fuel at tick over?
My Build Thread
AL_Mk1 said
Ah - now i'm even more jealous!!!!!
Sounds great.
Hi mate
I got the carbs and inlet off a guy that had them on an ABF in which he said, 'could do with setting up properly'. His ad said they was drilled to 190(main jets). I have'nt bothered to investigate if its true.
Going to see how she does on the rolling road on wednesday before i fit larger jets.
Its damn quick though. Traction is a big problem now lol
Only note was the drivers side ball joint has a little play so i'll swap them both.
Also found out that my fuel return line has been leaking and from the looks of it, it happened when i hit a log in the road some time ago. No bother as its not needed for the carbs so i'll chop it back and cap it off closer to the tank.
Gave it some beans on the way home, my god does it go now 8O 8)
Removed the return fuel line as it was leaking, blocked it off at the tank instead.
Also fitted a Choke cable as my R1 carbs like a bit when starting from stone cold.
Tidied up abit so my bay now looks like this
![](https://vwgolfmk1.org.uk/uploads/pbextract/1080727/IMG_0151.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1080727/IMG_0152.jpg)
Rolling roading the car on wednesday so i thought i'd use today to jack the front up as it'll be dark by the time i'am home in the week.
:redfaced:
![](https://vwgolfmk1.org.uk/uploads/pbextract/1080727/IMG_0153.jpg)
