Owned it for one week and headgasket has gone
dizzy needed a very slight twist and she fired up a good un……………. got a timing light at the car boot this afternoon will get her all timed up later……………. went for a spin all seems good
big thank you to everyone for their help and advice
Ok then 17 -19 BTDC :dontknow: :dontknow:
so i have taken of the dizzy vac hose and pluged it cars warm and idleing at 800 Rpm get the timing gun all conected up….
and this is what i see…….
the red line being the timing mark….. now is this BTDC or is it ATDC the haynes manual makes it sound as though its ATDC which makes no sense as the direction the engine turns surely would make this BTDC????? also how do you now what 17-19 degrees is????
atdc = after top dead centre
tdc = top dead centre
what this mean is the timing of the spark
so btbc means the when the piston is coming up the barrel and compressing the fuel it firsts btbc
now i not sure on how to set it with a normal timing gun as i have a varible on which can be ajusted to the right figure
